Tube Radio Forum
Knight tube tester
2 posters
Knight tube tester Empty Knight tube tester
Post by minerwelder Tue Apr 06, 2021 6:48 pm
I just picked up a Knight tube tester, after looking on the net for hours found old Knight catalog pictures the 1956 had Knight in a different script but had the 14 voltage choose like mine the 1958 catalog had the same script as mine but 16 voltage chooses so I'm thinking mine is a 1957, Its working but resistors are out of spec and cap is a wax paper I just got my Mouser order with the parts, so now the work begins. ? the anode lead is to small to go on 6F5G or a 6K7G is there an alligator clip our a different push on cap I can get. Kevin
minerwelder
minerwelder
Number of posts : 5
Registration date : 2021-04-06
Knight tube tester Empty Re: Knight tube tester
Post by Dale H. Cook Tue Apr 13, 2021 9:42 am
minerwelder wrote:the anode lead is to small to go on 6F5G or a 6K7G is there an alligator clip our a different push on cap I can get.
Top caps came in two diameters - 1/4" and 3/8". The connectors are called "grid caps" although some power tubes used them as anode caps. If yours is too small it must be a 1/4" grid cap. Some testers had a pin jack and two leads, one with each size of grid cap.
Dale H. Cook
Dale H. Cook
Number of posts : 114
