Tube Radio Forum
Bought a New LCR Meter
Bought a New LCR Meter Empty Bought a New LCR Meter
Post by Dale H. Cook Thu Nov 05, 2020 2:44 pm
A very useful piece of test equipment is an LCR (Inductance-Capacitance-Resistance) meter. I have owned one for many years for field use to evaluate inductors and capacitors.. I have a laboratory grade instrument in the shop - a General Radio Type 1608-A Inductance Bridge, but it is too big and heavy for field use.
For about 25 years I used an inexpensive LCR meter in the field. It was an Elenco LCR-1801 that had a guard terminal (used with shielded leads to reject noise and RF) but only measured to 200 uf. In recent years it has developed problems including a failure of one of the flat spring contacts for lead contact and problems with the rotary function/range switch. I decided to replace it, preferring the convenience of a battery-powered handheld LCR meter to the more cumbersome but more functional line-powered meters such as the Sencore Z-meters. I consulted fellow engineers who own LCR meters, and through a combination of reading manuals and reviews and borrowing meters for tests I reached a decision.
I bought a DER EE DE-5000 meter made in Taiwan. It has been rebranded by Extech, IET Labs, and possibly others. I learned that IET Labs, who bought most of the General Radio instrument designs, had rebranded this meter when a fellow engineer, whose DE-5000 mater I borrowed for testing, pointed out that he uses a PDF of the all-English IET manual in preference to the multi-lingual manual packed with the DE-5000. The fact that a company that manufactures high-quality impedance-measuring instruments for the bench would rebrand and sell this meter was an important consideration in my choice. It measures to 20,000 uf (values of 10,000 uf and higher display as millifarads), 2,000 H, and 200 Megohms (measured with DC or AC). It has selectable AC measurement frequencies in decade steps from 100 Hz to 100 kHz. It can also measure D, Q, Theta and ESR. It can measure in 4-wire mode, has guarded terminals, and a calibration function to compensate for the test leads used. I ordered mine with guarded alligator clips (with short 4-wire leads) and guarded 4-wire lead SMD tweezers. I passed on the factory external guard lead, preferring to roll my own using test lead wire that was much more supple than what the factory used. I also bought a pair of inexpensive Kelvin clips and rolled my own 4-wire Kelvin leads with guarded 2 foot leads made from RG-174. I also added a 25,000 uf 16 volt electrolytic cap (measured with my General Radio 1608-A impedance bridge at 27.4 millifarads) that I can use in series with an unknown capacitor for values above 20.0 millifarads. I have around $150 invested and have been well pleased with my DE-5000.
Dale H. Cook
Dale H. Cook
Number of posts : 114
Bought a New LCR Meter Empty Re: Bought a New LCR Meter
Post by Chas Thu Nov 05, 2020 11:04 pm
Very nice Dale...
I have but one of the instrument functions in my lab at the moment. I cannot easily measure inductance, nor ESR.
I have trusted your judgements in the past. This instrument seems it has a good pedigree and will do all in a handhelds.
I just priced it at $129. I might get myself a Christmas present, early...
Chas
Chas
Number of posts : 173
Post by electrojim Sun Dec 13, 2020 12:41 pm
Although I gave up vacuum tubes in the mid-'60s, I retain a soft spot in my heart for all the radios I cut my teeth on in the '50s, and lurk here '...for nostalgia's sake.'  On the matter of meters, I was lucky to latch onto a nifty little hand-held inductance/capacitance meter crafted in small runs by AADE (Almost All Digital Electronics).  This is extremely accurate and so handy in circuit development, but sadly the inventor/manufacturer passed away and it's no longer available.  You can see it here:
https://www.mtechnologies.com/aade/lcmeter.htm
I also find the current crop of 'offshore' test bench "do-all" meters quite handy, and these do give a measure of ESR for caps, except they call it something else and it's not quite ESR, but close enough.  These are available on Amazon and eBay very inexpensively... for instance:
https://www.amazon.com/KOOKYE-Mega328-Transistor-Tester-Capacitance/dp/B019SXN2M2/ref=sr_1_2?dchild=1&keywords=R%2FL%2FC+meter&qid=1607880886&sr=8-2
This family of cheap, clever devices has greatest utility in identifying and testing all sorts of transistors, but it will ID and read resistors, caps, inductors and diodes as well. I have found, however, that many coils fool the device into thinking that they are defective components of another kind.  Both testers are out-of-circuit types
electrojim
Number of posts : 6
Registration date : 2011-03-06
Post by curly Wed May 12, 2021 6:33 pm
DER EE DE-5000 is a nice meter, picked one up myself few months back Smile very happy with it
curly
Number of posts : 4
Registration date : 2021-02-04
Post by electrojim Sun May 16, 2021 1:06 am
Just got mine today. I guess they forgot the English translation in my user's guide, but found a complete manual online. Looks to be a very nice piece of gear!
electrojim
Number of posts : 6
Post by electrojim Wed May 19, 2021 3:58 pm
Hey, guys!
First a big thanks to you for turning me onto this piece of test gear.  It's amazingly accurate and can do so much.  Probably an ongoing learning situation, but very glad I have it.
The manufacturer sent me a PDF manual in English, which is essentially the same as that one on the Web.  I can't abide reading manuals off a computer (or phone!) screen while trying to use the device, so I have taken the manufacturer's manual and re-paginated it for duplex-printing onto letter-size paper... 4 manual pages to the sheet (front and back).  These are arranged so that printed double-sided they fold into a booklet in the right order for reading.  Glad to share the file if anyone's interested.
electrojim
Number of posts : 6
