type 80 vs 83 vacuum tubes
type 80 vs 83 vacuum tubes Empty type 80 vs 83 vacuum tubes
Post by acbaker123 Sat Aug 08, 2020 4:55 pm
can a type 83 full wave mercury vapor rectifier be used in place of a type 80 full wave vacuum rectifier, if not what are the differences. I have an 83 and a radio that needs an 80, can i use it?
acbaker123
Number of posts : 49
type 80 vs 83 vacuum tubes Empty rectifier 80 and 83 tubes
Post by Dan Walker Sat Aug 08, 2020 7:01 pm
https://www.antiqueradios.com/forums/viewtopic.php?f=19&t=250830
This link will give you the information you need to make a decision.
I hope it helps you . Dan in Calgary
Dan Walker
Number of posts : 154
type 80 vs 83 vacuum tubes Empty Re: type 80 vs 83 vacuum tubes
Post by Chas Tue Aug 11, 2020 7:31 pm
In a word NO.
The 83 draws more filament current, has less voltage drop and the ionizing action causes RFI, a conventional filter circuit without RF chokes would cause noise in an AM radio...
80's are cheap unless for a cosmetic reason a 280 "S" bulb (globe or balloon) is desired.
The 83 is commonly used in a few tube testers because of the regulation and low voltage drop the ionize mercury cloud provides.
Chas
Chas
Number of posts : 150
