1930 echophone tube search
I have a 1930 echophone S-3 that i need to find tubes for, all but the type 45 (245 in schematic) are cheap. the type 45 though is $60-$150 are there cheaper alternatives?
acbaker123- Member
- Number of posts : 49
Re: 1930 echophone tube search
I bought off of Ebay a while back a pair of adapters that used 45 sockets and you plugged 1619 tubes into those and they functioned the same as a 45 tube but at alot less expense. I think i bought the adapters and 1619 tubes for a total of around $30, so there are ways around it. Otherwise just keep a sharp eye out for a reasonably priced pair of 45's.
Here's what the set up looks like
Tony V- Moderator
- Number of posts : 754
how can you replace an old speaker like one that has an excitation coil with a new permanent magnet speaker
acbaker123- Member
is the adapter a standard pinout or are there different ones, disregard the speaker question, i figured it out.
acbaker123- Member
The pin-out to the 45 socket will always be the same. The socket in the adapter will vary in connection configuration depending what tube is used for a substitute.
Chas- Member
- Number of posts : 150
