Tube Radio Forum
stereo balance questions
4 posters
stereo balance questions Empty stereo balance questions
Post by acbaker123 Mon Apr 20, 2020 2:14 pm
on my zenith phonograph console whenever i adjust the volume the balance goes way off. is this normal? if now do you have any suggestions as to what the problem is? thanks
acbaker123
Number of posts : 81
stereo balance questions Empty Re: stereo balance questions
Post by Tony V Mon Apr 20, 2020 2:46 pm
If this is a dual pot volume control, it might be as simple as cleaning both pots with something such as deoxit fader lube. Is the control noisy at all?
Number of posts : 764
Post by acbaker123 Tue Apr 21, 2020 9:47 am
it isn,t noisy at all and i did thoroughly clean the pots with normal deoxit and crc brand electronics cleaner
acbaker123
Post by mr_ed01 Tue Apr 21, 2020 12:16 pm
Have had that problem on two 60's stereo amplifiers.  In both cases it turned out to be bad / worn volume controls
which developed a large difference in the resistance of the front and rear sections of the control.  The Heathkit volume control was replaced by a miniature dual 1 meg control from Ebay, works / tracks well.  The Fisher now has a trim-pot installed in the left channel so the balance is reasonable at 'normal' listening levels.
mr_ed01
Number of posts : 128
Post by jerryhawthorne Tue Apr 28, 2020 11:43 am
Just measure the resistance of both pots at several different degrees of rotation. Do they agree fairly closely? If they do look into the audio output section as you may have a weak channel due to a number of possibilities.
Number of posts : 708
Registration date : 2012-10-12
