Zenith phonograph console problems
I have a zenith phonograph console that i am trying to get working,(it has a large 7B30 chassis in the bottom and a smaller one where the knobs are at the top). while i gave done that it still has in my mind some issues. i replaced all the wax capacitors in the upper chassis with new film ones of the same spec, and a couple of old electrolytic with new counterparts. on the main chassis i didn't do much but replace the resistors attached to the center cathode (i think) on the 6bq5 because they were different and they upset the balance.on this console it requires me to fut a voltmeter on a couple of terminals and adjust for zero volts on both channels, i tried this but could not get down to zero. the main problem i am having is that i can feel voltage on the phonograph and the metal knobs on the front of the unit. i can also hear the loud pop of an arc when i turn the switch off on the phonograph. does anyone have any ideas? i am pretty new to tube stuff but i do sort of know my way around. i attached a couple of photos but i can take more
acbaker123- Member
- Number of posts : 50
Re: Zenith phonograph console problems
Is this a set with a power transformer or one without? If it is one without a transformer, it is considered a "hot" chassis and will have a safety capacitor going from one leg of the ac line to ground. If this capacitor is missing or defective, the unit can introduce ac to the metal parts as you describe. On some units, you can reverse the plug at the wall and stop the ac from coming through but that safety capacitor is likely the culprit and should be checked.
Tony V- Moderator
- Number of posts : 754
it has a transformer and i know which capacitor you are talking about, i put a polarized line cord on it and i will look into the cap, thanks
acbaker123- Member
You need to replace all the wax and, electrolytics in lower amplifier, and, power supply chassis.
Bill Cahill- Admin
- Number of posts : 4423
