Tube Radio Forum
Small Problem--But I need Help!
Small Problem--But I need Help! Empty Small Problem--But I need Help!
Post by RK-Rookie Fri Sep 13, 2019 4:58 pm
I am building my first single tube Radio kit. I broke the lead on a 47K resistor & I have a 51K resistor. Is it to big to use as a replacement or should I order a 47k?
Thanks, RK-Rookie
RK-Rookie
Number of posts : 6
Registration date : 2019-09-12
Small Problem--But I need Help! Empty Re: Small Problem--But I need Help!
Post by Tony V Fri Sep 13, 2019 6:23 pm
Most resistors are within 20% +/- tolerance so a 51K should work. It may reduce voltage slightly in the circuit your using so if you have any performance issues you can change it back later if need be.
Number of posts : 762
Post by RK-Rookie Sat Sep 14, 2019 12:48 am
Tony....Thanks for the fast Reply! Its hard for me to think that something so small could have much effect, but I am just an old retried Plumber!
RK-Rookie
Number of posts : 6
