Replacing capacitors - what's the diff tubular vs bakelight, mica, etc.
Replacing capacitors - what's the diff tubular vs bakelight, mica, etc. Empty Replacing capacitors - what's the diff tubular vs bakelight, mica, etc.
Post by jerhutch on Fri Mar 29, 2019 11:11 pm
The schematic shows some "tubular...", "bakelight...", "mica....", Do I need to be concerned with these descriptions when ordering?
Thanks
jerhutch
Number of posts : 1
Registration date : 2019-03-29
Replacing capacitors - what's the diff tubular vs bakelight, mica, etc. Empty Re: Replacing capacitors - what's the diff tubular vs bakelight, mica, etc.
Post by jukeboxman on Fri Mar 29, 2019 11:54 pm
hi welcome to TRF
it all depends on where in the circuit--really  about the only caps you need to replace are the coupling and filter caps
https://www.justradios.com/
this site has some Good info --on what is available--
check the useful links section on our site for many more resources of parts and supplies.
GARY
(Jukebox Man)
jukeboxman
jukeboxman
Number of posts : 197
Post by Spivey on Sat Mar 30, 2019 4:17 pm
One of the things about replacing capacitors is the value of the original cap. For example you may have 100mf at 450volts. Go with the same values as listed where you can. You might not be able to get a 100 microfard cap so you would need to get the next closest value. On the voltage stay with the voltage listed. Again just an example of what you might find. The other would be the type of capacitor as to radial or axial. Are the leads coming out of one end or one on each end. Hope this helps.
Spivey
Number of posts : 43
