Electro model P Battery eliminator
Electro model P Battery eliminator Empty Electro model P Battery eliminator
Post by juker17 on Fri Aug 10, 2018 7:30 pm
Hi, does anyone know very much about this item? I have a schematic. Replaced caps and im reading 164 V when I should be reading 90V . Nothing hooked up. Does it need a load to read correctly. I replaced all caps. One big strange cap installed. I believe its 1000MF , red , grn, and black wires going to it. I assume its electrolytic , but the schematic is vague on this. Thanks, Jim
juker17
Number of posts : 3
Registration date : 2018-08-10
Electro model P Battery eliminator Empty Re: Electro model P Battery eliminator
Post by John Bartley on Fri Aug 10, 2018 7:35 pm
Yes, they need loading, and to test how much loading they'll need you can sub in resistors in place of a radio until you get to a voltage that makes you happy. Some ohms law calcs will tell you if the radio will be safe.
John Bartley
Number of posts : 127
Post by juker17 on Fri Aug 10, 2018 10:28 pm
Thanks John for the info. Further troubleshooting , and I dont have my 1.4 V "A" output. Nothing coming out of the rectifier. The rectifier in the schematic is confusing, looks like full wave, but both outputs coming out of the + sides of the rectifier. Do you have a schematic of this to look at? Thanks, Jim
juker17
Number of posts : 3
Post by juker17 on Mon Aug 13, 2018 2:32 pm
Im all set on this except for the instructions, anyone have the instructions?
juker17
Number of posts : 3
