Painting bakelite
Painting bakelite
i know everyone has an opinion and I'd appreciate the input. I just spent 2 hours sanding old paint and and filling scratches and dings. I think I'm ready to paint but just the thought of missing a crucial step and starting over again makes me want to throw up. I have several questions:
1. I have filled holes and with bondo and sanded with 400 grit. Is that sufficient?
2. Assuming my sanding is good what's the best primer?
3. After painting I heard guys say they use brasso and rub to smooth out the dimples in the primer. Yes , no?
4. so I get a a good smooth primer finish ready for paint, whats your "go to" paint?
5. Spray can paint or mix and use paint gun(which I have)?
6.Now that I have a paint and applied a light coat, dry or wet sanding between coats ?
7.How many coat do you suggest and do you sand the last coat new apply a top coat?
Thanks,
Ben
Thanks,
Ben
Ben Delk- Member
- Number of posts : 440
Re: Painting bakelite
For the Bakelite sets I've done, I've sanded to about 220 grit. That always seemed fine enough to give a smooth surface and coarse enough to give some "tooth" for the next coats to cling to. The last thing I do before I prime is wipe the surface with either a tack rag or a clean, lint free rag dampened with reducer or thinner. I always prime with automotive primer. It's hard and sands out well for the finish coat. The choice of application and paint type has to do with the colour and style. If you're doing pastels you may find them in premixed "rattle cans" at the store. The last one I did was a hammer-tone and I bought hammer-tone silver base and tints which I sprayed thru' a small automotive siphon type gun.
Anyway, that's what I've done. There will be many methods and types of paint and equipment to prep and apply with. None are right or wrong. The right method is the one that works for you.
John Bartley- Member
- Number of posts : 129
Sounds like a good plan, thanks
Ben Delk- Member
John, do you clear coat after painting bakelite?John Bartley wrote:For the Bakelite sets I've done, I've sanded to about 220 grit. That always seemed fine enough to give a smooth surface and coarse enough to give some "tooth" for the next coats to cling to. The last thing I do before I prime is wipe the surface with either a tack rag or a clean, lint free rag dampened with reducer or thinner. I always prime with automotive primer. It's hard and sands out well for the finish coat. The choice of application and paint type has to do with the colour and style. If you're doing pastels you may find them in premixed "rattle cans" at the store. The last one I did was a hammer-tone and I bought hammer-tone silver base and tints which I sprayed thru' a small automotive siphon type gun.
Ben Delk- Member
No I don't Ben. After the paint has cured for a couple of weeks, if it looks too glossy/plasticy I wash the cabinet with soap and water and a soft rag, then buff it out by hand. Otherwise I leave it alone. I've only done a few (maybe 10 or 12), but I've never clearcoated anything except wood cabinets and they were a lacquer finish over toned wood.
Just a note ... this is just how I've done them, but I'm no expert and I'm certainly not a painter ....I fix chainsaws for a living. Maybe do an old scrap cabinet for practice and to develop a technique that works for you?
It would be nice if someone with more experience would chime in with an opinion.
cheers
