Philco 38-620
Philco 38-620 Empty Philco 38-620
Post by pbc64 Tue Nov 17, 2015 12:35 pm
I will be trying to get a picture to load thanks
Hello I need some advice on a philco 38-620 cabinet. Its important I find this color to match.I know also they made these out of maple and walnut I believe mine is walnut so what color is this cabinet thanks paul
the cabinet looks orangy
Last edited by pbc64 on Tue Nov 17, 2015 1:36 pm; edited 2 times in total (Reason for editing : can not get picture to load)
pbc64
pbc64
Number of posts : 13
Philco 38-620 Empty Re: Philco 38-620
Post by willy3486 Tue Nov 17, 2015 2:43 pm
I am not sure of what you are needing the color for? To match the wood to fill in a missing piece? Anyway when I redo a case I like this that was suggested to me. I had a couple I have redone the finish recently. I will strip off the bad finish if it can't be saved. Then I use the lacquer that is in a spray can. It seems to go on good and leaves a good finish. One of the radios I redid I had to make the top for it. I made the top then darkened the new wood. When I got it as similar as I could I then went over the entire case with a light stain. It seemed to mix together good. Considering how bad the case was I think it turned out decent. Someone had nailed it together with nails that had big heads instead of some type of finishing nail Shocked . I had to fix the "repair " as well.
Number of posts : 1390
Post by Bill Cahill Tue Nov 17, 2015 8:27 pm
The walnut finnish cabinets were done in medium brown walnut. Some trim parts tended to be done in a darker stain, sometimes black.
Number of posts : 4423
Philco 38-620 Empty philco 38-620
Post by pbc64 Wed Nov 18, 2015 3:33 am
Thank you the top of the radio needs new veneer and the front is in nice shape and i do not want to mess with it.I will go with that color thank you
pbc64
pbc64
Post by 75X11 Fri Nov 20, 2015 10:53 pm
