What does it mean
What does it mean
When your tuning dial is toooooo sensitive. I am still trying to get this RCA X551 aligned properly. The stations come it, some are loud, some are not so loud. The tuning dial is why to sensitive I think, you have to move it super slow to lock in on the station, and then you get bleed over from another station not all. Mostly the ones that are close by i.e. 15 minutes or so up the road.
Frank
Frank
frank1956- Member
- Number of posts : 409
Re: What does it mean
Did you give the tuning capacitor a real good cleaning at it's bearings and leaf springs? It is important they maintain constant connection throughout the tuning range.
75X11- Member
- Number of posts : 4453
IF you have a direct-drive tuner, where the tuning knob is mounted directly to the tuner shaft, it can be hard to get the station dead on. A geared-down tuner drive makes this easier. You probably should be glad the radio works at all, considering all the problems you have been having, Frank. It is good for the radio to be sensitive.
Wildcat445- Member
- Number of posts : 4893
WC, This radio has the direct-drive tuner. Yea you are right I should be glad it is working period!!! By the way did you get the PM I sent you?
Frank
Frank
frank1956- Member
One thing back in the day of radios like this, they adapted a lever to help tune, such as a large diameter rubber belt over the knob or even made a kluge and used a pencil or a tongue depressor glued for leverage.
The other issue may be that the AVC may not be working.
If you get station bleed over then alignment may need tweaking or it could be a tube.
Resistance is Futile- Member
- Number of posts : 913
