Help!
Help!
I own a 1968 Zenith model Y960 and it was damaged on the inside of the cabinet that houses the turntable during transport across country. The turntable was NOT anchored in place and it chewed up the wood cut out that the turntable sits in and is supposed to be anchored to during such transport. My question is this: Can this piece of wood be replaced at all? It appears to be rather solidly built by Zenith and glued into place. If it can be; does anyone have a similar unit that if possible they would be willing to remove their turntable and send to me a decent tracing of the openings actual size so that I can have a pattern to hire a furniture maker to custom make this piece for me. All other aspects of this unit are near mint and I would hate to have to toss it because this happened to it. The sound is phenomenal!!
I would sincerely appreciate any and all ideas and or assistance.
Regards,
Larrym
Regards,
Larrym
larrym- New Member
- Number of posts : 2
Registration date : 2014-05-14
Re: Help!
Hi, Larry. First off, welcome to TRF! This is a great bunch of folks who are happy to help.
Just in the way of a suggestion, you might be able to get a piece of lauan, which is the thin wood used to make door facings. It is easily finished and worked. It comes in 1/4 inch thickness, which does not take up much room. Depending upon how your cabinet is configured, you could reverse trace, cut out and just set the changer on this surface, and not have to get into expensive cabinet restoration. You could stain and finish the lauan so it would match the cabinet finish. Good luck.
Wildcat445- Member
- Number of posts : 4893
Re: Help!
Do you have a photo of the damage? It might be a help for suggestions on fixing it.
willy3486- Member
- Number of posts : 1390
Re: Help!
I will take a photo asap and post it. Thanks for the suggestion as you will be able to see the extensive damage to the opening even with the turntable in place!
Regards,
Larrym
Regards,
Larrym
larrym- New Member
Re: Help!
Welcome to TRF..............
Bill Cahill- Admin
- Number of posts : 4423
