Tube Jukebox mp3 mod?
Hi all,
i recently acquired a Seeburg 147S trashcan, my first. Has anyone connected an mp3 player to one? If so how do you go about it? I'm new to this so please don't slap me around too hard
Right now I am in the process of recapping the amp, but I did get her to play through an external amp.
Thanks
Thanks
Vincenzo- New Member
- Number of posts : 3
Registration date : 2014-02-28
Re: Tube Jukebox mp3 mod?
Welcome to TRF.
A line-level input to the audio stage should get you going. Good luck.
Wildcat445- Member
- Number of posts : 4893
Welcome to the site.
Do you have a link to the schematic?
You'd want to provide a tap into the "hot" side of the volume control.
You will want to provide isolation so there is no risk of shock. This and combining stereo signal can be achieved by using two small audio transformers that are still available from Radio Shack I believe.
Maybe you have already figured something out, but you will need a way to turn on the amp without activating the record selector assembly and turntable. Some jukes just keep the chassis "lit" all the time, some only fire up the chassis when a selection is made.
Just some thoughts.
Just some thoughts.
Dr. Radio- Member
- Number of posts : 899
I have one of the trashcan jukeboxes. Seems like there is a volume control on the right hand side looking at the back. It will have a odd cover over it with two holes. It was made like this to keep patrons from cutting it up. You had to have a key for it. In mine I unscrewed the odd cover and put a regular nut on it. It can be turned then with a screwdriver. It might take the same nut that some switches or pots use. The jukebox has a few boxes inside that all plug into it together. You can probably setup a box to hold the transformers in the back close to the volume control to keep it original.
willy3486- Member
- Number of posts : 1390
Trashcan mp3 input
Willy,
I cut a piece of wire hanger and curved it to fit the two holes to of the volume control on the back you mentioned to be able to rotate it a while back, you can also get the key from victory glass, which I might do in the future.
The boxes you mention are the amp and solenoid units. I don't have a remote speaker unit on my box. But how do I go about adding an input to the amp and having it turn on without engaging the record player? If you can outline as many steps as you can as I said i'm new to this. thanks
