Hippo Philco 46-420 code 125
Starting on my (Hippo) Philco 46-420 code 125. Nostalgia only goes to code 121 and the electrolytics are different so I wonder what else is differenent. I have the chassis open and it all looks pretty straight forward and all the caps are marked with values. I'd just like to have a schematic that matches up for my files and records. Anyone have one you's like to share?
Thanks,
Ben
Thanks,
Ben
Ben Delk- Member
- Number of posts : 440
Re: Hippo Philco 46-420 code 125
Sams 6-22 also appears to be code 121
mr_ed01- Member
- Number of posts : 120
Ben,
Maybe we can help each other out...just looked at my "hippo"....model 46-420 code 125!
Been sitting over a decade due to time and lack of schematic.
I'd like to compare notes. I foolishly didn't record some connections in the filter circuit so it's been sitting a-mess. Between both, maybe we can figure things out?
The biggest difference I believe is the 50B5 output tube where others used an octal style tube.
Dr. Radio- Member
- Number of posts : 899
Riders only lists code 121.
Wildcat445- Member
- Number of posts : 4893
Code 128 uses a 35Y4 rectifier and a 50B5 output tube
mr_ed01- Member
Try: Chuck Schwark,
The Philco Repair Bench
http://www.philcorepairbench.com
ea327- Member
- Number of posts : 71
There are other differences, and, I don't have the schematic to fix mine.. My has a four wire antenna, and, one different tube, yet,, uses the octal output, and, the 35Y4 rectifier...........
Bill Cahill- Admin
- Number of posts : 4423
simplex1040- Member
- Number of posts : 299
Sorry guys, I have not had a chance to re-visit this information. I have not had time to touch a radio since the first of May. I've been re-modeling my mother's house since pop past away. I hope to get back to radio repair by late fall but that is "iffy" at best. I'll jump in every now and then to see if I have anything to respond to. Catch up with you later.
Blessings,
Ben
Blessings,
Ben
Ben Delk- Member
