Tube Radio Forum
Clock Motor Lubrication
4 posters
Clock Motor Lubrication Empty Clock Motor Lubrication
Post by Guest Thu Jan 10, 2013 10:22 pm
I was reading about the procedure to lubricate the sealed rotor assemblies used with electric clocks and I remembered seeing small hand operated vacuum pumps sold to test automotive engine vacuum systems. a vacuum sealed jar could be used with one and make a small low vacuum chamber to evacuate the air from the sealed assembly and then allow it to draw the oil in without having to heat it and take the time waiting for it to cool. Northern tool and Harbor Freight sell such pumps. It bwill probably be some time before I restore a clock movement, so I thought I would put forth the idea.
Clock Motor Lubrication Empty Re: Clock Motor Lubrication
Post by Bill Cahill Thu Jan 10, 2013 11:32 pm
You could carefully drill a very tiny hole in the case of the gear assembly, making sure NOT to let the drill bit hit the gears inside that assembly, and, put in some good quality oil, shake it well, and, let it lie for a day. Carefully attempt to turn the drive gear. If it turns, put assembly back together, and, try. Usually, this will fix it, and, motor will be fine. The problem is the oil inside gums up, and, gears seize.
Number of posts : 4432
Post by Guest Fri Jan 11, 2013 4:08 pm
I used to do rebuilds on alert monitors that had pots that were not practical to open up. I would drill two small holes in their cases, inject cleaner into them and use canned air to get most of the liquid out. then lightly heat with a heat gun. That would restore the pot's function in most cases.
Post by Guest Fri Jan 11, 2013 10:14 pm
I would always have a number of the spray tubes and would take a piece of wire of the inside tube diameter, slide a piece inside and heat the plastic to soft. You can then twist the plastic on the wire into an hourglass, and cut it at the center and slide the wire out. It would make a nice fine point on the tube.
Post by Ken g Sat Jan 12, 2013 8:15 pm
out
Ken g
Number of posts : 222
Post by Guest Sat Jan 12, 2013 9:54 pm
Many of the pots that I would drill would have had a greater chance of damage with the larger bits that would accomodate an unaltered tube. It was a simple and quick mod for the tube and that enabled me to use a 1mm drill.
Post by Guest Sun Jan 13, 2013 2:02 pm
Tried one of my new .6 mm bits on the housing of a burned relay.
Clock Motor Lubrication P1000337yc
Post by Dr. Radio Thu Jan 24, 2013 9:15 am
I've been using a secondary method to the one I wrote about on my site, much faster, but needs a write-up and I can't upload to my web space due to technical issues. It does involve opening a hole in the rotor--I still prefer keeping them 100 % factory sealed.
Number of posts : 899
Post by mistercarter Sun Jan 27, 2013 9:12 pm
Re: Telechron sealed clock motors. I have had great success silencing and rejuvenating sealed motor modules by drilling a small hole in the top of the case (relative to the drive gear) and introducing graphited lock fluid. I applied this technique more than twenty years ago to my father's 1953 Crosley E75, and the clock remains silent and accurate to this day.
mistercarter
Number of posts : 1
Registration date : 2013-01-27
