Tube Radio Forum
SW tower
SW tower Empty SW tower
Post by willy3486 Sun Oct 21, 2012 12:00 am
I just picked up three sections of a rohm ham tower like this one
http://www.americanlisted.com/minnesota_23/misc_117/antenna_tower_150_merrifield_mn_13325129.html
Its two sections teen feet long and one that is the top piece with the tube in the center to hold the antenna. I am wanting to set up a antenna so I can hook up a antenna to am radios and a hallicrafters s38 SW radio. Anyway I was thinking about putting some glass insulators on top then run a wire for a antenna. Has anyone done a setup with a tower for a radio? I do have a used TV antenna but its so so. I was wondering is a wire,maybe 50 to 100 ft from it to a insulator on the other end would work better. Anyone know pictures of a setup like it.
Number of posts : 1391
SW tower Empty Re: SW tower
Post by sprman Sun Oct 21, 2012 10:24 am
Verticals tend to pick up lots of noise. A sloping wire from the top down may work better.Best would be a inverted L or longwire at right angles to power lines.Sprman
sprman
Number of posts : 323
Post by willy3486 Sun Oct 21, 2012 12:30 pm
What I have been thinking is to put 2 wires or more on the top of the tower. Put them on the glass insulator. Then put the tower up and pull the wires over to a barn about 75 feet away from where I will place the tower next to my shop. The wires would be gradually sloping down to about 10 feet from the ground. The one thing I worry is about a lightning strike. How bad are they to attract lightning? I always disconnect antennas but one time years ago I had lightning hit my antenna then jup around to items in my shop. It burned up a transistor in a tv that wasn't even connected to the power or antenna.
Post by sprman Sun Oct 21, 2012 5:23 pm
That would work but use a lighting aresster to be safe.Be careful in everyhing you do make sure the ant and tower can not fall and hit any power lines! Sprman
sprman
