GE 516F - static and intermittent reception after playing for 10-15 minutes
Page 2 of 2 • 1, 2
Re: GE 516F - static and intermittent reception after playing for 10-15 minutes
Here's the 2nd IF. To my inexperienced eye, I would say the wafer looks pretty bad. The spec on the caps is 75pf. I just need to find a couple and solder them in and test it. Meanwhile, the replacement I found is working like a champ. Radio has been playing for a little over 3 hours now. Nothing like listening to oldies on an oldie.....and working on radios.
foxcovert- Member
- Number of posts : 24
Registration date : 2011-04-09
Yep. That's the problem. Then, you can keep that one as an extra when first can gets bad enough, or, just replace forst can.
Replacement is fine.
Bill Cahill- Admin
- Number of posts : 4423
Let's see...
The 9th posting to this thread was me, suggesting stocking up on 100pf silver-mica caps. (because I knew what the problem was.)
Was that not enough of a hint?
Oh well.
Oh well.
repairtech- Member
- Number of posts : 97
Well glad you got it fixed and have it playing...Sprman : )
sprman- Member
- Number of posts : 323
1st if quit now. Since 1st and 2nd are identical, repaired the one with a pair of micas and it works like a champ again. thanks again gang for the help.
foxcovert- Member
Page 2 of 2 • 1, 2
