A cheap source for rubber spacers
I have posted this on other forums,
but I'll post it here as well. Frequently on older wooden sets of the 1930s they used either springs or rubber spacers to cushion /dampen vibrations to the radio's chassis. There are a number of sources that make replica rubber spacers, but a cheaper alternative and one you can use in a pinch is to go to your local hardware store and get some foam rubber pipe insulation. It comes in various diameters and is easily cut with scissors or a razor blade.
An idea would be to cut the rubber to the size you need , make sure it fits in the routered out hole for it on the baseboard of the cabinet, once you get it to size and shape you could use it just as is, or maybe wrap a layer of the painters masking tape around the outside to make it look more like the color of the original spacers. Just a suggestion is all.
LarryC- Member
- Number of posts : 73
Re: A cheap source for rubber spacers
That is a smart one... I used to use caulking glue... WHAT A MESSS... NEVER AGAIN I SAY
Oldsmobile Man- Member
- Number of posts : 131
Hmmm, that maybe a little too permanent of a repair job.
LarryC- Member
I cast it on the floor of the garage, and i got more on me that the cast! I only made the mistake of putting it dierectly on the radio once... smells bad when burning
