crosley phono
crosley phono
Post by denver on Mon Nov 01, 2010 12:38 pm
I have recapped the whole set . Has radio and phono. Radio playing great . Phono just makes humming sound .
Like a bad filter cap makes but i put ALL, new caps in. The table spins changer works. It just hums through speaker.
Any info Thanks Denver. model 03CQ.
denver
Wise Man
Wise Man
Number of posts: 381
Registration date: 2010-01-18
Re: crosley phono
Post by Tony V on Mon Nov 01, 2010 7:40 pm
I would check the cartridge because if its open, it will cause the humming sound that you describe. Also check the tone arm wiring for any shorts or loose wires all the way to where it connects to the chassis. Disconnecting the tone arm plug at the chassis will tell you if its a cartridge or wiring problem. If disconnecting it still produces hum then theres a wiring problem in the radio itself.
-Tony
Senior Member
Senior Member
Number of posts: 109
Registration date: 2008-09-13
Re: crosley phono
Post by denver on Tue Nov 02, 2010 5:38 pm
Thank you very much. Iwill do and let you know.
Thanks again Denver Smile
denver
Wise Man
Wise Man
