Some goo!
Some goo!
Post by denver on Tue Sep 28, 2010 9:20 pm
Ok on my Crosley i noticed some tar / goo. Has leaked out of the transformer.
Somebody must of tried to play it with a disconnected electrolytic cap i found.
I have ordered all the caps . Do you think the trans is fried?
It is not a lot of goo. Rolling Eyes
Thanks Denver. Very Happy
denver
Wise Man
Wise Man
Number of posts: 381
Registration date: 2010-01-18
Re: Some goo!
Post by kb4yrc on Tue Sep 28, 2010 10:34 pm
Give it the " ol' smell test ". If it smells burnt, probably is ...... Gregg
kb4yrc
Number of posts: 21
Registration date: 2008-05-20
Re: Some goo!
Post by sprman on Wed Sep 29, 2010 6:09 pm
You can ohm it out,or lift the output leads and check for voltage.It chould have overheated.. Sprman...
sprman
Wise Man
Wise Man
Number of posts: 258
Registration date: 2008-03-27
Re: Some goo!
Post by denver on Wed Sep 29, 2010 7:26 pm
Thanks . It does not smelled burn,t . Someone before me
spliced the wires from trans i will check voltages there.
Thanks again Denver.
denver
Wise Man
Wise Man
Re: Some goo!
Post by Stan Ski on Tue Oct 12, 2010 6:09 pm
If i remember correctly an easy way to test the transformer is to remove all the tubes and power it up slowly. If there is no smoke or smell the transformer should be OK. This is only a test for the transformer.
Stan Ski
Stan Ski
Number of posts: 31
Registration date: 2008-05-17
Re: Some goo!
Post by denver on Wed Oct 13, 2010 6:54 pm
Thanks for the info. Will check waiting on caps ect .
Place i ordered from must have slow mail
denver
Wise Man
Wise Man
Re: Some goo!
Post by Nick666 on Mon Dec 06, 2010 6:12 pm
You may be able to tell if it's ok by removing all the and any dial lights and plugging it into a dim bulb tester.If the transformer is good the bulb should not light, but if it's bad the bulb will come on at full brightness.
Nick
Nick666
Number of posts: 40
Registration date: 2010-10-22
