Capacitor size
Capacitor size
Post by bill57 on Sat Sep 11, 2010 12:22 pm
Working on a Stewart Warner R-1254 that has two 12uf/600v filter capacitors. Can't find this exact value anywhere in 600V. I can get a 10uf or a 20uf at 600v. I don't want to drop down in voltage so do I go slightly less at 10uf or do I almost double the size to 20uf? I could double up and do a 10 and a 4uf for 14uf.
Any advice on this?
bill57
Senior Member
Senior Member
Number of posts: 81
Registration date: 2009-01-21
Re: Capacitor size
Post by denver on Sat Sep 11, 2010 6:49 pm
Iwuld not go 20% above or below. This place will have thenhttp://www.vacuumtubesinc.com Very Happy
denver
Wise Man
Wise Man
Number of posts: 381
Registration date: 2010-01-18
Re: Capacitor size
Post by denver on Sat Sep 11, 2010 6:52 pm
denver wrote:Iwuld not go 20% above or below. This place will have thenhttp://www.vacuumtubesinc.com Very Happy
You can go 450 volts will be fine.
denver
Wise Man
Wise Man
Re: Capacitor size
Post by sprman on Sat Sep 11, 2010 7:13 pm
Hi the 10 or 20 will do fine.Stay with the 600 volts never go lower voltage.I would use the 20 @600 v ...The 10 will work with a bit less filtering.Todays caps are much better than what they had back then.Sprman : )
sprman
Wise Man
Wise Man
Number of posts: 258
Registration date: 2008-03-27
Re: Capacitor size
Post by bill57 on Mon Sep 13, 2010 7:24 pm
Thanks for the input on this. I'll stay at the 600v and try the 10 and 20 and compare the two.
bill57
Senior Member
Senior Member
Number of posts: 81
