Crosley 03cq
Crosley 03cq
Started working on this. The turn table was stuck So the motor run rubbing a gouge in the
wheel that turns the turn table . It is a metal wheel with rubber on it . What would be best way to fix this?
Has anyone run upon this before.
Thanks Denver.
Thanks Denver.
denver- Wise Man
- Number of posts: 380
Registration date: 2010-01-18
Re: Crosley 03cq
Definitely have seen this a few times. The rubber is probably hard as a rock too. West-Tech services can redo your wheel but it is expensive.
http://www.west-techservices.com/p7.htm
If it isn't too bad I have successfully cut rubber from a tire tube and contact cemented it on. May need a couple layers. A thick rubber band also works however none of this will hold up to daily use. If you just use it occasionally this could be a cheap fix depending how bad of a flat spot you have.
bill57- Senior Member
- Number of posts: 81
Registration date: 2009-01-21
Re: Crosley 03cq
Thinking about the rubber band route . Will not be played much. Thank you for the info. Denver
denver- Wise Man
Re: Crosley 03cq
You could use Rtv to fill in the gap. It will take some work, but you could let the RTV dry the use sand paper or knife or file to smooth out the RTV to be concentric. In other words spin the wheel while dressing the rubber portion to become smoothly rounded.
Resistance is Futile- Admin
- Number of posts: 581
Re: Crosley 03cq
Thought about something like that. But like bill said rubber is about shot. Thanks much for the info.
Denver
Denver
denver- Wise Man
Re: Crosley 03cq
I did what you both advised . Filled in the gouge bought a big bag of rubber bands for 1.50 . If one wears out change it like a spare tire.
Oh on the motor the shaft that turns the big wheel is it suppose to have rubber on it too? If so it must of rubbed off when it got stuck.
denver- Wise Man
Re: Crosley 03cq
No. And, those rubber bands won't last.
Re: Crosley 03cq
Just won,t to get it spinning for looks . Have other sets with phonos.
Thanks .
Thanks .
denver- Wise Man
Re: Crosley 03cq
denver wrote:Started working on this. The turn table was stuck So the motor run rubbing a gouge in the
Thanks Denver.![]()
http://www.dialcover.com/idler.html found this real helpful .
denver- Wise Man
Similar topics» crosley 03cq.
» Crosley Showbox Speaker....
» Crosley 179
» WTB - Working speaker wth intact wiring for a Crosley Super 11 Model 1111 or 1117
» Crosley model 515 low volume
» Crosley 179
