Tube subs and wiring changes
Post by Resistance is Futile on Wed Aug 18, 2010 12:59 am
This Sylvania Tube substitution booklet has diagrams for changing tubes wiring pin to pin when specific tubes cannot be found. I thought this might be of use. It may also be used for tube tester applications when sockets need to be modified and a particular tube isn't listed in the tube chart.
So if you can't find a needed tube, (such as happened during the war) you can still get the set to operate on a different tube.
There is also a section on TV tubes. This Reference manual was printed in 1953..
Click Here
Last edited by Resistance is Futile on Tue Feb 07, 2012 11:30 am; edited 1 time in total
Number of posts: 581
Re: Tube subs and wiring changes
Post by sprman on Fri Aug 20, 2010 7:24 pm
Handy dandy link you posted.Sprman ! : )
sprman
Wise Man
Wise Man
Number of posts: 253
Registration date: 2008-03-27
Post by tube radio on Sat Aug 21, 2010 9:13 am
Thanks for the link.
tube radio
Senior Member
Senior Member
Number of posts: 184
Registration date: 2008-07-24
Post by Brig on Mon Feb 06, 2012 6:04 pm
Resistance is Futile wrote:This Sylvania Tube substitution booklet has diagrams for changing tubes wiring pin to pin when specific tubes cannot be found. I thought this might be of use. It may also be used for tube tester applications when sockets need to be modified and a particular tube isn't listed in the tube chart.
http://www.vacuumtubeera.net/S ... l-1953.pdf
Clicking on your link brings up a message that it cannot be found. Too bad; I've wanted to have this information for a long time. Bill, can you revise and provide a viable link?
Brig
Number of posts: 21
Registration date: 2011-08-18
Post by Resistance is Futile Yesterday at 11:31 am
I have Edited the first link, so you can try that.
Click Here
Post by Brig Yesterday at 3:21 pm
Got it! Thanks.
Brig
Number of posts: 21
