One tube regen does not receive local station at 580 KHz
Hello,
I am new to this forum.
I recently built a one tube Armstrong regen from a kit. It is sold by Borden Radio Company, Radio Daze and another company whose name I forget. The tube is a 3S4 which will take up to 45 Volts DC on the plate. It works well with 22.5 Volts. I have tried two antennas. The first is a 40 foot "short" wire antenna in my apartment. The second is the aluminum window frame in my bedroom. Booth work equally well. The radio works without a ground.
I get the 3 local stations above 1000 KHz but cannot receive the 50 KW local station
at 580 KHz. Do any of you know what I could do to receive the 580 KHz station?
Thanks.
Robert
Thanks.
Robert
Last edited by ve2age on Mon Aug 09, 2010 11:22 am; edited 1 time in total (Reason for editing : typo)
ve2age- Noob
- Number of posts: 4
Registration date: 2010-08-09
Re: One tube regen does not receive local station at 580 KHz
You might try replacing the caps, one at a time, and make sure the tunning cap has no shorts. If you can also test the tube. You may have used the wrong cap in your building it.
Resistance is Futile- Admin
- Number of posts: 627
Thanks Cliff.
Robert
Robert
ve2age- Noob
Look for cold solder joints or check the coil .. Sprman : )
sprman- Wise Man
- Number of posts: 258
Registration date: 2008-03-27
Thanks Sprman.
Robert
Robert
ve2age- Noob
you might ck the two bypass cap's on the RF chock to be sure they are not swaped or in the the wrong place. the one i built from scratch works great. will send u schematic if you need it!
pawpawhunt- Noob
- Number of posts: 5
Registration date: 2011-11-10
Thanks for the advice pawpawhunt. About a year ago, I
got the solution from someone on another forum. It is to connect a cap (I forget the value) between the tuning cap and the chassis ground. It is connected with aligator clips (and insulated sleeving). It is disconnected to receive higher frequency stations.
A change in the number of turns on the coil might eliminate the need for the fixed cap. Lance Borden, who sells the kit, is aware of my thoughts on the subject.
Robert Cherry
Robert Cherry
ve2age- Noob
Similar topics» Richborough ower station 14th june 2010
» Tube locations... (I know)
» New Tube Head?
» Blackstar HT-5 Tube Swap
» HT-60 Bias mV Readings-Bad Tube?
» New Tube Head?
