CAN CAPS
CAN CAPS
Post by denver on Fri Jun 25, 2010 8:42 pm
Whats best way to get these cans off chassi ? Getting ready to re cap my philco 37 - 93 Rolling Eyes
denver
Wise Man
Wise Man
Number of posts: 381
Registration date: 2010-01-18
Re: CAN CAPS
Post by GaryRabbitt on Tue Aug 10, 2010 12:27 pm
Hi Denver,
I don't know exactly what your cap can looks like, but on a model 84 I have, there is a clamp holding the cap in place.The cap may be insulated from the chassis. Like a cardboard cap but is clamped.
You mentioned "cans" os you might have 2 that are either clamped, or have large nut on the bottom. Again, these may be insulated from the chassis, or may touch the chassis, check your diagram.
http://www.nostalgiaair.org/PagesByModel/228/M0013228.pdf
UPon looking at your diagram. I se only one cap can, and it appears to be clamped. Probably a cardboard tube instead of a can?
I would suggest that you first ID all the leads going to the cap.
I assume you want to restuff the cap right? Otherwise there would be no reason to remove it, except for cleaning.
If not, just leave the old cap in place, and disconnect the wires going to it.Install your new caps in place under the chassis.
Let us know if that is what you need.
Gary.
GaryRabbitt
Number of posts: 35
Registration date: 2008-07-04
Re: CAN CAPS
Post by denver on Tue Aug 10, 2010 6:08 pm
Thanks for the info. Figured it out set is playing better any set i have. Where have you been full of great info. Very Happy
denver
Wise Man
Wise Man
Re: CAN CAPS
Post by GaryRabbitt on Thu Aug 12, 2010 11:17 pm
denver wrote:Where have you been
Generally on the ARF forum or the Philco Phorum like most of the other members here. Hope to visit here more often.
GaryRabbitt
Number of posts: 35
