looooong wire
looooong wire
Ihad a long wire antenna run about 70 feet high . Thought i had after 9pm radios only. only time get anything.
Then had idea . Telephone i only use two wires in the interface box out side . The other two are for extra lines .
So i hooked onto these two wires now i have a loooong wire antenna work great . Doesn,t cause any problem with phone try it .
Denver.
Denver.
denver- Wise Man
- Number of posts: 381
Registration date: 2010-01-18
Re: looooong wire
Careful of lighting,it can come in the lines!I use a 110 foot longwire 20 feet up works great here. Sprman : )
sprman- Wise Man
- Number of posts: 258
Registration date: 2008-03-27
loooong wire
Iam in the mountians of Virginia. Down in a valley so low .
denver- Wise Man
Re: looooong wire
Lighting can go anywhere.Being in a low valley a nice longwire say as long as you can make it would helpOne thing to watch is noise... I moved my ant so its as quite as i could find.Helps for weak DX.Sprman : )
sprman- Wise Man
Re: looooong wire
Thanks will try.
denver- Wise Man
Re: looooong wire
Finally have a good working long wire antenna. Ran a piece
of 10 gauge wire in a L shape 200 foot long and 20 foot up.
Picks up a station all over the dial. And all day long.
Got this ideal off of some guy named Sprman.
Have to finish with lighting protection and earth ground.
Then i will be finished with it .
denver- Wise Man
Re: looooong wire
If this is a non-transformer operated set, that is series string tubes, it is highly reccommended against using a ground.
This is a shock hazzard, and, if grounded, and, if plug is reversed, you will be shorting one side of the ac line to the other.
Re: looooong wire
It is a 1931 model 11 tube . It will be fine thanks for the concern. And a 1949 5 tube.
denver- Wise Man
Similar topics» Organizer/reel for bonsai wire
» clip and wire raft
» Heavy Duty Wire holder HD Movie
» cutting the red wire on each pickup at the tone pots
» Wire vidoes- Wisevid
