mica condencers
mica condencers
Post by denver on Tue Apr 06, 2010 4:53 pm
What do you think about replacing them. Rolling Eyes
denver
Wise Man
Wise Man
Number of posts: 380
Registration date: 2010-01-18
Re: mica condencers
Post by denver on Tue Apr 06, 2010 5:00 pm
Here[url]www.philcorepairbench.com/micacap.htm[/url]
denver
Wise Man
Wise Man
Re: mica condencers
Post by sprman on Tue Apr 06, 2010 5:38 pm
Depends,testing them takes time so does replacing them..Replacing them can take a lot of time and money.Up to you if you replace them or not.I replace if im keeping the set.I find most times they are good to go so i dont replace them..Sprman Smile
sprman
Wise Man
Wise Man
Number of posts: 253
Registration date: 2008-03-27
Re: mica condencers
Post by GaryRabbitt on Tue Aug 10, 2010 1:19 pm
denver wrote:What do you think about replacing them. Rolling Eyes
I don't think you should shotgun all your micas, unless you are having a specific issue with one of them.
I am all for replacing one if it is found to be bad. No doubt. As Angelo says, you can do them all, but run up your repair bill.
With a little diagnostic work, you should be ale to isolate the area of the trouble.
If the set is working well, leave 'em alone. They won't cause damage like an electrolytic cap would.
GaryRabbitt
Number of posts: 30
Registration date: 2008-07-04
Re: mica condencers
Post by denver on Tue Aug 10, 2010 6:11 pm
Thanks again. Smile My problem is working on to many sets at the same time.
denver
Wise Man
Wise Man
Re: mica condencers
Post by GaryRabbitt on Thu Aug 12, 2010 10:59 am
denver wrote:Thanks again. Smile My problem is working on [i]too[/i] many sets at the same time.
Maybe a little ADHD Smile I know what you mean. I will get one set going, then have another I think I can do fast. Never happens.
It does help to keep the parts in boxes, otherwise I may misplace parts in another areas.
I found that staying with only one, at least until I repair the chassis and it is working, then I can do various ther parts of the resto. Cleaning, cabinets, etc.
GaryRabbitt
Number of posts: 30
