someone painted it metalic purple
Post by jopusbob on Wed Mar 31, 2010 12:06 pm
recently acquired a new radio and someone painted the bakelite this metalic purple. is there a solvent that i could use to remove the paint without eating the plastic?
thanks
jopusbob
Number of posts: 7
Registration date: 2010-03-29
Re: someone painted it metalic purple
Post by denver on Wed Mar 31, 2010 4:06 pm
Only thing i ever used was lestoil or pinesol get at walmart.
Take chassi out &speaker have to get enough to soak radio in .Sometimes takes few days. It will start lifting paint then
use a stiff brush not wire. till its off.
denver
Wise Man
Wise Man
Number of posts: 381
Registration date: 2010-01-18
Post by sprman on Wed Mar 31, 2010 8:06 pm
Man another one painted ,i see that at swap meets and in junk stores flea markets.Grrrr wish they did not do that.Sprman
sprman
Wise Man
Wise Man
Number of posts: 258
Registration date: 2008-03-27
Post by Resistance is Futile on Wed Mar 31, 2010 9:02 pm
Just think, of the challenge and how it gives you something to do. This will help you to do finishing techniques you would otherwise not be able to develop.
Idea
Number of posts: 627
Post by jewel's old time radio's on Thu Apr 01, 2010 7:58 pm
you can get paint remover at any hardware store that should work
Number of posts: 32
Registration date: 2010-02-26
http://web.me.com/jewelpim/jewelsoldtimeradios/welcome.html
paint
Post by denver on Thu Apr 01, 2010 8:20 pm
paint remover will mess bakelite up . If it doesn,t melt right away it will. It gets into it . Then if you did end up having to paint it again something besides purple. It would not stick.
denver
Wise Man
Wise Man
Post by RUBBERCHICKEN on Wed Oct 13, 2010 1:42 pm
i use Easy-off oven cleaner the original formula soak the cabinet down with it and put it in a trash bag leave it overnight and usally it will wash off paint with water if it dont remove all get what you can with water and a scotch brite pad and then resoak it with easy off oven cleaner and let it sit a litttle while longer it should take it off if its not factory paint also i use a plastic bristle brush while rinsing the old paint and easy off of it just remember to were rubber gloves the easy off will cause a burning sensation to exposed skin i restore them old painted broken and painted bakelits all the time so give my method a try heres my website go look at restoration section and radio collection of some of them ive done
my website http://jimstuberadios.tripod.com/
RUBBERCHICKEN
Number of posts: 43
Registration date: 2008-03-15
