Voltage down
Voltage down
Philco model 111 voltage at electrolytic caps around 475 .Checked filter choke checks good resistors check good.
This will probaly put a strain on transformer &80 recitifier tube . Any way i can get voltage down in the line ?e
Checked everything for a short it calls for a 4.7uf@450 volts . Keeps blowing it . Put a 20mfd@450 doesn,t blow.
THIS IS ON TERMINAL 10 IN BIG CAP BLOCK. The other electrolytic cap from terminal 9 to 3 does fine.
Any ideals THANKS DENVER.
denver- Wise Man
- Number of posts: 381
Registration date: 2010-01-18
Re: Voltage down
oh 10 also goes to 3 THE REST OF CAPS PUT WHAT SCHAMATIC CALLS FOR MAYBE YOULL UNDERSTAND THIS
1&2 TERMS TIE TOGETHER GOES TO #11 #4 #5 #6 #7 TO#11 THEN #8 TO#9 TO# 3 THEN # 10 TO #3 IN BIG CAP BLOCK ALL RATED AT 630 VOLTS EXCEPT ELECTROLYTIC CAPS 450VOLTS #11 CHASSI GROUND
RAN POLARITY RIGHT ON THE ELECTROLYTICS
denver- Wise Man
Re: Voltage down
OK check the speaker field coil to see if its shorted.Look at the 80 output that goes to 2 resistors check them.Have you ckecked tube socket resistanes for all tubes.Check the 45 tubes sockets for shorts to ground same with the 80.Check for and globs of solder that might short out to ground.Sprman : )
sprman- Wise Man
- Number of posts: 258
Registration date: 2008-03-27
Re: Voltage down
WILL DO LET YOU KNOW
THANKS DENVER
THANKS DENVER
denver- Wise Man
Re: Voltage down
THANKS SPRMAN LED ME ON TO SOMETHING .
THIS IS A BIG CONSOLE I WAS CHECKING VOLTAGE WITH SPEAKER UNHOOKED. DIDN,T WANT TO TAKE SPEAKER OUT
ITS A BIS ONE. HARD TO CHECK WITH SPEAKER IN RADIO
MANAGE TO VOLTAGE ALL RIGHT . I WAS CHECKING WITH NO LOAD ON CHOKE .
THANKS DENVER
THANKS DENVER
denver- Wise Man
Re: Voltage down
Ahh yes have done that myself befor.Hope it plays good for you.Sprman : )
sprman- Wise Man
Similar topics» Low Rectifier Voltage output after SDS Cap board install.
» ST70 Voltage Chart
» high voltage on speaker terminals of Mk4?...
» unstable bias voltage
» ST-70 Rectifier Voltage Readings
