CAPS
CAPS
Ihave some 20 through 40 mfd electrolytic @450 VOLTS .Can i use them instead of 4.7 uf @450 volts?
Be used in a big cap block .
Denver
Denver
denver- Wise Man
- Number of posts: 380
Registration date: 2010-01-18
Re: CAPS
For power supply circuits, you can go as high as 100% of the original value but it can raise your voltage. For any other application, I wouldn't go over 20% of the original value.
Motorola man- Senior Member
- Number of posts: 82
Registration date: 2010-02-06
Re: CAPS
A 10 mfd would be ok even a 12mfd.Allways keep same voltage.Sprman : )
sprman- Wise Man
- Number of posts: 253
Registration date: 2008-03-27
Re: CAPS
If the cap is too big it will load down the power supply in trying to charge them up. Too much current and then poof! on the power supply. You had better stay with the 100% over and no more to be safe I would say myself 20% and no more. As suggested by Motorola man!
Resistance is Futile- Admin
- Number of posts: 579
Re: CAPS
Thanks alot lot of help'.
Denver
Denver
denver- Wise Man
Similar topics» Shane Caps - ER - Updated 26th June 2009
» Dyna MKIII fallen short of upgradeing caps.
» All the Video,Picture,Screen Caps of WTTR!!
» k40-y caps
» Budget replacement caps, ST 70
» k40-y caps
