RADIO PLAYS GOOD THEN GETS QUIT
Post by denver on Tue Feb 09, 2010 4:27 pm
Philco model 111 . All new caps resistors , checked antenna coils ,good .
Plays good for awhile then quits receveing . Sometimes it makes a pop sound through speaker plays good for awhile then quits.
Any body run upon this before.
Thanks denver
denver
Wise Man
Wise Man
Number of posts: 381
Registration date: 2010-01-18
Re: RADIO PLAYS GOOD THEN GETS QUIT
Post by sprman on Tue Feb 09, 2010 7:20 pm
Check the tube pins and sockets.Check and clean the band switch if it has one they can cause all kinds of troubles.Recap the set if you have not done that.See if you can find any bad solder joints .Sprman : )
sprman
Wise Man
Wise Man
Number of posts: 258
Registration date: 2008-03-27
what kind of band switch
Post by denver on Wed Feb 10, 2010 9:09 am
Iwas leaning on the band switch to. It is like a reagular toggle switch on top underneath has little stacked card board peaces
Three prong connection . Every thing else checks out .
THANKS DENVER Very Happy
denver
Wise Man
Wise Man
Post by denver on Wed Feb 10, 2010 9:11 am
OH WAS WONDERING WHAT TO REPLACE IT WITH
denver
Wise Man
Wise Man
Post by sprman on Wed Feb 10, 2010 9:24 am
First try cleaning it several times.Look at it closely to make sure contacts are making full contact.Iwould replace it with the same kind from a junker set ect,if it is indeed bad.You may have to clean it 3 or 4 times and work back and forth to get it clean.Sprman : )
sprman
Wise Man
Wise Man
Post by denver on Wed Feb 10, 2010 10:01 am
think i could use just a drop of oil on it looks rusty on toggle? Rolling Eyes
denver
Wise Man
Wise Man
Post by sprman on Wed Feb 10, 2010 10:24 am
No oil !Try alcohol to clean it .Oil will short it out.Any spray contact cleaner will work too.Sprman : )
sprman
Wise Man
Wise Man
Post by denver on Wed Feb 10, 2010 11:01 am
T hanks will do Denver in Wise VA.
denver
Wise Man
Wise Man
Post by denver on Thu Feb 11, 2010 1:23 pm
Found out carb cleaner work great fast drying to. Just about dries as fast as you clean it.
denver
Wise Man
Wise Man
Post by Resistance is Futile on Sun Feb 14, 2010 1:34 pm
Caution with carb cleaner as it melts plastics.
You might also look for intermittent resistor as heating up over time it will crack open so look for both hairline cracks and poor solder joints.
Number of posts: 627
