Halton model 64-1
Halton model 64-1
Looking for a schematic diagram for a Halton model 64-1 radio. All the electrolytic and paper capacitors were replaced, but the sound in garbled. None of the mica ones were replaced. The speaker was torn, but was tested on another radio and it played ok. When I received it the audio output tube was broken and had no markings. Based on what little I could read from the label on the case, I replaced it with a 50L6. All the other tubes are readable (35Z5, 12SQ7, 12SK7, 12SA7). All the tubes have been tested. I am sure of the model number because it was still readable. Someone in the past had replaced some resistors using series and parallel replacements. Was Halton manufactured by “THE HAROLD LIFTON COMPANY”?
Picture at:
http://s981.photobucket.com/albums/ae299/regent_album/halton/?action=view¤t=halton64-1radio.jpg" target="_blank
Picture at:
Last edited by regent on Thu Feb 04, 2010 3:50 pm; edited 1 time in total (Reason for editing : add picture link)
regent- Noob
- Number of posts: 8
Registration date: 2009-10-28
Re: Halton model 64-1
Have you tried Nostalgia Air?
Sounds as if someone really messed this one up. Sounds like you have the correct tube in it.
First thing check all tube voltages.Use tube date to be sure they are at right voltages.Check resistors in the audio section for changed values,or for opens,shorts.Replace caps in PS.Sprman : )
sprman- Wise Man
- Number of posts: 253
Registration date: 2008-03-27
Similar topics» Model prezentare !
» [MODEL] Cerere Rank
» BR's Model Cars & Merchandise
» [BT72] Premium Model - Haruka Osawa [MF ?????]
» Halton model 64-1
» Halton model 64-1
