Motorola Chassis 6-2 - Superheterodyne
Post by rufuskane on Fri Jan 08, 2010 5:28 pm
I am taking on the challenge of restoring this model radio - mfg. year 1943. The finished radio is a model 6T / 115V / 50-60 Cycles / 75 Watts.
Upon inspection the power cord was badly cracked and needs to be replaced. What I don't know is proper way to begin inspection without damaging the radio. If anyone has any patience I am interested in learning. I don't want to simply replace the power supply cord and create a larger problem by just plugging it in. Any help would be great.
Thanks.
rufuskane
Number of posts: 1
Registration date: 2010-01-08
Re: Motorola Chassis 6-2 - Superheterodyne
Post by Bill Cahill on Fri Jan 08, 2010 9:51 pm
First of all, the power supply electrolytics will need neplacing. They tend to dry out, and, short.
Next, the paper capacitors get electrically leaky, and, need replacing, You should also check all your tubes to make sure you have a good set of tubes in it.
Also, several of the mannufacturers also used at least some rubber wirring, which the insulation tends to rot, crack, and, flake off, which can cause nasty short circuits.
I would never reccommend just plugging it in without a proper inspection, and, restoration first.
Number of posts: 782
http://billcahill.webs.com/
Post by Alfred Corbin on Thu May 13, 2010 9:10 pm
Before recapping, I would cautiously try it on a Variac or give it a dim bulb test. You might find it works, at least to some extent, and then you could make all the replacements under careful control. In the very worst case, it's not likely you could do much damage by application of limited power for a second.
Alfred Corbin
Number of posts: 14
Registration date: 2009-02-11
http://antiqueradiorepair.net
Post by denver on Thu May 13, 2010 9:55 pm
Your set is a 6t you will need a schematic. it is here[url]www.nostalgiaair.org[/url] Order capaciters here [url]www.vacuumtubesinc.com[/url] and anything else you need speedy delivery . This is a great place will get plenty of help . Welcome aboard . Very Happy
denver
Wise Man
Wise Man
Number of posts: 380
Registration date: 2010-01-18
Post by Motorola man on Fri May 14, 2010 6:55 pm
http://antiqueradio.org/begin.htm is a great site to help you learn the basics. The Motorolas are usually pretty simple beginner sets, they're well layed out and easy to work on. As Bill said, replace the rotted or corroded wire, caps and bad resistors. I also recommend adding a fuse and a polarized plug for a little added safety. Just a little heads up, Motorolas are very sensitive to electrical noise. I can't use either of mine within about 15 feet of a computer (even after replacing ALL of the wiring, caps & resistors).
Motorola man
Senior Member
Senior Member
Number of posts: 82
Registration date: 2010-02-06
