Socket cleaning
Socket cleaning
Hello I have a Philco 50-926 and noticed that one of the sockets for one of the tubes looks like its discolored from aging.I would like to clean the socket.Whats tool and or brush would i use? Contact cleaner?? thanks john
narrowfarm- Noob
- Number of posts: 5
Registration date: 2009-10-31
Re: Socket cleaning
If its just age discoloration, use a scribe and scratch the outside of the pin where there is no contact with the tube pin? If so, can you see bright shiny metal? If so it is just minor oxidation.That being the case, you could try a pipe cleaner with rubbing alcohol as a start to remove any oils, then you could try brasso metal polish and cleaner, on a clean pipe cleaner. Then re-clean with alcohol.
If that doesn't work then:
Does it show on only one Socket pin?
Proceed to check the solder connection on that pin. It may be bad. If its a bad connection or not a tight pin contact, that might have lead to the overheating and discoloration. As a last resort you can use a solution of vinegar and salt it acts as a copper and silver cleaner and should restore the bright silver color.
Be sure to rinse with clear water to remove the salt. Or you will get further corrosion.
Resistance is Futile- Admin
- Number of posts: 627
Re: Socket cleaning
I also understand that Pipe tip cleaners for gas welding torches work also.
Similar topics» home made cleaning products
» Socket cleaning
» Cleaning Dynaco chassis (ST-70) - please share your experience and tips
» Cleaning Calcareous deposits from trunks and pots...
» Ah Jeh has no difficulty in cleaning the house and toilet, but is afraid of taking care of babies
» Socket cleaning
