Hi, I'm new to the forum...
I recently picked up at a yard sale a Zenith Model T350, Chassis 7M07 tube radio. My first foray into the tube radio world. My goal is to someday own a '50s or '60s era, RCA Victrola monorual record player. Can't remember the exact year of my mothers player, but I'll notice it when I see it. Baby steps first though...
Back to the radio, on the bottom of the radio is a piece of paper that says... Patented in Canada by Zenith Radio Corporation in one of the following years 1946, 1949, 1950, 1951. Then a date in small print, 1-30-59, I suspect that to be the production date for the radio?
I opened up the rear of the chassis and found the inside to be loaded with decades of dust. Nothing burned or damaged. All tubes are present. However, when I turn it on I get a mid to low frequency hum (AC noise?). The pots for the volume and tone control are dirty and need to be cleaned. I've read somewhere that the selenium rectifier could be bad. Also that I should replace all of the paper/wax caps, resistors etc. What contact cleaner would you recommend for the volume and tone controls?
If anyone has anymore info to throw my way I'd greatly appreciate it. If I needed tubes, is there a hobbyist or a company out there still supplying them?
Thank you,
RustyFuryIII
Thank you,
RustyFuryIII
RustyFuryIII- Noob
- Number of posts: 1
Registration date: 2009-09-10
Re: Hi, I'm new to the forum...
Welcome to TRF!
-Tony
-Tony
Tony V- Senior Member
- Number of posts: 102
Registration date: 2008-09-13
Welcome to our forums....
Any selenium should be replaced, as well as paper capacitors, and, electrolytics. Sounds lke your electrolytics are going south.
Not familiar with this model set, but, sounds like that year is about right.
Be very careful if you haven't done any radio restoration yet.
We have an excellent beginner's tutorial section here that should get you started.
Good luck.
Good luck.
Tubes and parts are available from a lot of differant sources. Some in Canada and mostly in the States. Some parts can be found through members here or at least a friendly point in the right direction.
Gordon- Member
- Number of posts: 27
Registration date: 2008-11-05
Similar topics» Forum Recommendations
» Forum Guidelines
» Suggestions for the forum
» + ReMeMbEr My FoRuM!! +
» GLOBAL FORUM RULES
» Forum Guidelines
