Philco 49-900 12 “hippo” radio antenna connections
Post by breadboard88 on Fri Sep 22, 2017 7:16 pm
This Philco 49-900 12 “hippo” radio has a permanently installed antenna in the Bakelite case.
It came to me with the fine antenna wires disconnected from the chassis.
It looks like they might go to a fiber terminal with 3 soldering lugs mounted on the chassis to the rear of the tuning cap.
I can‘t figure which wire goes to which of the 3 tabs. There is also one fine wire coming off of the tuning cap lower soldering lug and I am not sure where it goes.
Bob............
breadboard88
Number of posts : 2
Registration date : 2017-09-22
Re: Philco 49-900 12 “hippo” radio antenna connections
Post by CaptainClock on Fri Sep 22, 2017 8:38 pm
Hello, I found a picture of a radio just like yours with the wires connected maybe this picture will help you out a bit.
CaptainClock
Number of posts : 81
Post by breadboard88 on Sat Sep 23, 2017 10:18 am
breadboard88 wrote:
Sorry, but I needed to change the wording on the original post.
It looks like they might go to a fiber terminal with 4 soldering lugs mounted on the chassis to the rear of the tuning cap.
I can‘t figure which wire goes to which of the 4 tabs. There is also one fine wire coming off of the tuning cap lower soldering lug and I am not sure where the other end goes.
Bob............
breadboard88
Number of posts : 2
Post by Chas on Sat Sep 23, 2017 3:03 pm
http://www.nostalgiaair.org/pagesbymodel/669/M0013669.pdf
Chas
Number of posts : 78
