Capacitors
Capacitors
Along with the tubes, there are 3 capacitors (10, 30 & 30) on the top of the chassis. Being new at this, I'm going to try replacing all the capacitors, but my question is this, should I replace those three large caps with the small ones, and place them on the inside of the chassis?
herromc- Member
- Number of posts : 15
Re: Capacitors
If there is under chassis space, I would do the capacitor replacement rather the surgery to the old electrolytic. This usually means installing a terminal strip to support the transfer of the wires from the old capacitors. The old capacitor must be disconnected from the center terminals. Wires to the metal shell can remain. Sometimes the capacitors can be located elsewhere under the chassis. Don't locate them in the RF/OSC section.
Be very aware of polarity, paper sleeved metal electrolytics often have the metal shell above the chassis ground. Sometimes the multiple electrolytic has a reverse polarity or a negative connection but not to the shell. Look the schematic over carefully...
GL
Chas
GL
Chas
Chas- Member
- Number of posts : 90
Registration date : 2008-07-25
» electrolytic capacitors
» capacitors
» ST70 Capacitors
» Russian Teflon FT-3 0.22uF 600V Capacitors
» Testing the Quad Cap ?
» capacitors
» ST70 Capacitors
