Zenith L721 bumble bee cap.
Post by terrydec on Wed Mar 15, 2017 2:07 pm
I had this great sounding Zenith L721 AM/FM radio. I gave it to a friend and it played great for awhile. Then it went zzzzpt and quit. He sent it back and when I opened it up I found a bumble bee cap had exploded. It comes from pin 3 of the output tube to ground, and of course I can't find it on the schematic. The markings are-
yellow, violet, orange, black, yellow. My guess is .047 mfd. What I really need to find out is why it exploded in the first place. I also need to replace the filter caps. Whooppee! Some fun, huh?
terrydec
Number of posts : 1111
Re: Zenith L721 bumble bee cap.
Post by terrydec on Wed Mar 15, 2017 3:16 pm
I figured it out. It's 470mmf. I got nuttin' like that. That would be a mica, right? Would a regular orange drop work? All I got are used electrolytics. It looks like an order to ARS.
terrydec
Post by easyrider8 on Wed Mar 15, 2017 5:22 pm
From pin #3 of the 35C5 to ground would be a .047 capacitor. Bumble bees in that position (across the line) are notorious for failing in that fashion. You would want to replace it with a "X" rated safety capacitor.
Dave
easyrider8
Number of posts : 50
Post by terrydec on Wed Mar 15, 2017 6:29 pm
Okay- I'm dumb. What is that and where do I get one?
terrydec
Post by easyrider8 on Wed Mar 15, 2017 8:14 pm
Send me a private message with your snail mail address and I will send you one.
Here is the info. http://www.kemet.com/Lists/Filestore/EvoxRifaRFIandSMD.pdf
Dave
easyrider8
Post by mafiamen2 on Thu Mar 16, 2017 1:43 pm
great info dave thanks
sam
mafiamen2
Number of posts : 97
Registration date : 2012-12-03
Post by terrydec on Thu Mar 16, 2017 2:42 pm
Yep!
Isn't this forum the best?
I think this one shorted. Would that take out the filter cap? This set played perfectly when I sent it out. Now it has hum and the signal is distorted.
terrydec
Post by terrydec on Thu Mar 16, 2017 2:45 pm
BTW- This set has a chassis ground. Dangerous. Good thing I have an isolation transformer. However replacing the filters will be a real challenge.
terrydec
Post by Bill Cahill on Thu Mar 16, 2017 5:47 pm
No, but, there's a good chance it took out one, or, more tube filaments. Pin 3 is one of the filament pins.
Number of posts : 4594
Post by terrydec on Thu Mar 16, 2017 6:28 pm
Bill Cahill wrote:No, but, there's a good chance it took out one, or, more tube filaments. Pin 3 is one of the filament pins.
It works, so the tubes are okay. The 30C5 was a little weak so I replaced it. I never worked on this radio because it played. I got it for the FM. Then I sold it to a friend. It worked great, but now it is distorted and hums. My friend says it made a funny noise, started to hum and stopped working. Is it possible that one of the electrolytic caps shorted? What about the Selenium rectifier? At least it still does pass a signal.
terrydec
Post by Bill Cahill on Thu Mar 16, 2017 6:52 pm
Could be, but, I'd replace that paper capacitor, first.
Post by terrydec on Thu Mar 16, 2017 10:54 pm
I'm gonna replace that cap and the electrolytics. Then I intend to bring the power up VERY slowly and see what I have then. I hate poking around in FM sets. I barely understand AM. And this has a hot chassis.
BTW- Thanks for all your responses.
terrydec
