Help with output transformer
Post by lhlyda on Sat Mar 11, 2017 11:23 am
Hey guys,
Working on the 1937 Howard 400x. Not more to go on than a schematic. Checked the output transformer and found the primary is open. Now, Im not good at this so, I need some input as to make sure Im headed down the right path. Attached is a picture of the schematic of the output amp. Here is the data I know.
12 inch 25 watt Jensen speaker
Voice coil reads about 5.4 ohms
Push pull 6v6 amp
Where Im calculating,
Input impedence should be about 8000 ohms for PP 6v6's
The 5.4 ohm speaker voice coil x1.25 is about 7 ohms. Lets say its an 8 ohm
That makes the impedance ratio 1000:1
The impedance ratio is the square of turns ratio making the winding ratio 31:1
Questions I have
What is the actual wattage of the circuit, in other words how much wattage should the transformer be rated for.
Based in the physical size of the transformer, Im betting its 15 watts or less.
What would be a good replacement electrically and physically
Thanks guys, attached are the schematic and pics
lhlyda
Number of posts : 50
Re: Help with output transformer
Post by John Bartley on Sat Mar 11, 2017 11:43 am
Tube data for SE and PP 6V6 : http://www.r-type.org/pdfs/6v6g.pdf
Based on a plate voltage of 215v ... output is less than 10W?
Just one of probably several choices? : http://www.edcorusa.com/gxppseries#/specFilters=7m!#-!53!-#!9!#-!259
Probably also a good idea to wait for some other opinions ...
cheers
John
John Bartley
Number of posts : 147
Post by lhlyda on Sat Mar 11, 2017 12:00 pm
Thanks John,
I was thinking on the order of 8 watts. How did u calculate that? Im sure with experience, you can probably have seen about the same circuit.
Thanks again!
Larry
lhlyda
Post by John Bartley on Sat Mar 11, 2017 12:04 pm
My audio experience is very limited, hence the suggestion to wait for other opinions. All I did was use your values, but ....
I think if it was me I'd use a 10k primary load, given that your plate voltage is down around 215? and the screen is at about 225? according to the schematic, and then by comparing that to the tube data in the linked PDF I'd come up with the 10k primary and less than 10 watts.
Probably best to digest that info and wait for someone who really knows....
cheers
John Bartley
Post by lhlyda on Sat Mar 11, 2017 4:37 pm
Ok, the best I can tell from other comments on another forum, Im on the right track. Plate should be about 219 v. Best I can figure about 8 watts.
Hammond T125c $49 and $51 shipped two places
AES p-T291 $28.44 shipped
The AES is closer physically than the Hammond- actually rechecked not that much different.
Hmmm,
Any opinions
Last edited by lhlyda on Sat Mar 11, 2017 4:41 pm; edited 1 time in total (Reason for editing : Added comment)
lhlyda
Post by John Bartley on Sat Mar 11, 2017 4:56 pm
I think it's pretty close, and for a universal transformer either will work. Given that mains voltages tend to run a bit higher these days than when the set was built, I'd budget for slightly higher plate and screen voltages than are spec'd on the schematic. That would drive me toward spending a tad extra and go for the 10 watt version.
However .... if you are only going to use it intermittently and no all day like they were originally built for, then either would probably do just fine. Also ... I doubt you are going to drive it to full power all the time.
cheers
John Bartley
Post by Bill Cahill on Mon Mar 13, 2017 9:44 pm
Eight to ten watts. Hmm. It's a car radio. Probably 6-8 watts. Id guess 8 K actual resistance.
Bill
Number of posts : 4590
