Fun Project.
Page 3 of 4 Previous  1, 2, 3, 4  Next
Fun Project. - Page 3 Empty Re: Fun Project.
Post by willy3486 on Wed Jan 25, 2017 7:56 am
Terrydec look at the second link page I posted. If you look at the diagram it shows that the am radio is being used simply as a amp for the signal. The added on parts of two caps and the diode is a simple AF/RF probe. If you have parts laying around make a probe by that diagram and instead of putting it into a radio put a connector you can plug into your tracer. Its simple to make and may solve your problem. I have used that tracer for about 35 years and have never had issues.
Number of posts : 1380
Post by John Bartley on Wed Jan 25, 2017 9:53 am
terrydec wrote:O
It turns out that I have been making a DC probe for a DVM.  This is a cap and resistor in series with a diode from the junction to ground.  The circuit I need has, I believe, a diode in series with a cap and a resistor to ground.
My understanding of this may be on a simple level, but .... I have always thought of an "RF Probe" as a portable device that simulates a detector and passes the product to an audio amp so that it can be listened to (ie : a signal tracer). So, it seems to me that a diode in series, with a capacitor to filter the RF after the diode, leaving just the audio signal is all that an RF probe is?  An audio probe has a DC blocking cap at the input and the signal does not have to be rectified (detected) before being sent to the tracer?
As far as the placement of the diode .... whether you block the RF half wave or send it to ground, does it matter how it's rectified?
There are people posting here who will correct and explain better than I.
John Bartley
Number of posts : 127
Post by terrydec on Wed Jan 25, 2017 11:51 am
willy3486 wrote:Terrydec look at the second link page I posted. If you look at the diagram it shows that the am radio is being used simply as a amp for the signal. The added on parts of two caps and the diode is a simple AF/RF probe. If you have parts laying around make a probe by that diagram and instead of putting it into a radio put a connector you can plug into your tracer. Its simple to make and may solve your problem. I have used that tracer for about 35 years and have never had issues.
It looks simple enough but I couldn't get the value of C2. Is that diode a signal diode?
terrydec
terrydec
Number of posts : 1124
Post by John Bartley on Wed Jan 25, 2017 12:41 pm
Hi Terry,
I see C1 as 0.01uf, C2 as 0.001uf and D1 as a 1N34 which I think is a germanium signal diode? I can't imagine that the cap values are super critical ... almost anything close should work?
John Bartley
Post by terrydec on Wed Jan 25, 2017 1:26 pm
Great. I need to get a new diode from Radio Shack but I'm definitely going to try this.
terrydec
terrydec
Post by willy3486 on Wed Jan 25, 2017 10:41 pm
John Bartley wrote:Hi Terry,
Yes, these are the values.
Post by terrydec on Wed Jan 25, 2017 11:03 pm
Well... I bid on another Tenma like mine , only with a probe. Once again I bailed out at $80. It went for $102. Too rich for my blood. I got mine for $45. I have my eye on a Heathkit in really good shape. I'm beginning to hate auctions.
terrydec
terrydec
Post by John Bartley on Thu Jan 26, 2017 10:00 am
terrydec wrote:Well... I bid on another Tenma like mine , only with a probe.  Once again I bailed out at $80.  It went for $102.  Too rich for my blood.  I got mine for $45.  I have my eye on a Heathkit in really good shape.  I'm beginning to hate auctions.
Yes, auctions are great for increasing stress levels Smile
John Bartley
Post by terrydec on Thu Jan 26, 2017 12:49 pm
With all the money I have spent to repair my GE Console I could have bought a new one. I am going to try once again with that Heathkit. I figure I'll just put in $200 and let the chips fall where they may. Then sell my Tenma.
terrydec
terrydec
Post by terrydec on Thu Jan 26, 2017 12:50 pm
Here is that Heathkit-
http://www.ebay.com/itm/222384325770?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
terrydec
terrydec
Post by John Bartley on Thu Jan 26, 2017 4:22 pm
terrydec wrote:With all the money I have spent to repair my GE Console I could have bought a new one.  I am going to try once again with that Heathkit.  I figure I'll just put in $200 and let the chips fall where they may.  Then sell my Tenma.
Terry,
Here's a link to the manual : http://www.pascalchour.fr/ressources/heathkit/it12.pdf  The schematic and component values for the probe are shown in the schematic if you're interested.   I'm looking forward to seeing how you make out with the auction.
cheers
John
John Bartley
Post by terrydec on Thu Jan 26, 2017 4:47 pm
Terry,
cheers
John
Thanks a bunch. It will sure be nice if I get that Heathkit.
These probes all seem to be the same, a high voltage cap and a germanium diode. I think I can do that. I saw one probe that was built in a section of copper pipe.
terrydec
terrydec
Post by terrydec on Thu Jan 26, 2017 5:36 pm
Theoretically, this should work.  Not my best solder work.
Fun Project. - Page 3 Dsc00013
terrydec
terrydec
Post by Dr. Radio on Fri Jan 27, 2017 8:52 pm
Wow, the Heathkit IT-12 on eBay just sold for $167.50!
I hope you didn't spend that kinda money on it Terry!
Number of posts : 899
Post by terrydec on Fri Jan 27, 2017 8:57 pm
I got it. You are not going to believe this. $168.50.
terrydec
terrydec
Post by terrydec on Fri Jan 27, 2017 9:03 pm
Now that the head rush has worn off, Ouch! Maybe I can get something for my Tenma. This had better all be worth it.
BTW- Thanks for being my substitute Facebook.
terrydec
terrydec
Post by terrydec on Fri Jan 27, 2017 9:42 pm
terrydec wrote:Here is that Heathkit-
Thanks. I just printed it out.
Okay- in my defense...I did just pay over $160 for a $50 tester. That might have been a little extreme. At least it is in excellent shape.
Why have I done this? I have this great console that I have invested a LOT of time and effort in. It will work great but after a few days shut down. I want to be able to inject a signal at the antenna and trace it all the way through the circuit. Somewhere there is a bad resistor or cap and I'm gonna find it.
Perhaps I can sell my Tenma while the market is so hot.
terrydec
terrydec
Post by Bill Cahill on Sat Jan 28, 2017 6:20 pm
Have you replaced all your capacitors? What do you mean shut down? Could be a bad tube, or, dirty tube sockets, also.
Number of posts : 4412
Post by terrydec on Sat Jan 28, 2017 7:46 pm
Bill Cahill wrote:Have you replaced all  your capacitors? What do you mean shut down? Could be a bad tube, or, dirty tube sockets, also.
I know,it could be any of those. Here's what it does...
I work on it and it starts to work. It works for several hours a day for a few days, then, usually when my back is turned, it just stops. There is another problem. Sometimes the volume will go up or down. I have replaced all of the caps in the RF area. I even removed the oscillator coil at some point. The 6SA7 is an NOS that I bought the last time I worked on it, a few months ago. That time I just changed the way the antenna was connected. This time I'm going to check the resistors. I might use some cold spray too. It is such a great sounding radio when it works.
terrydec
terrydec
Post by terrydec on Wed Feb 01, 2017 4:22 pm
Okay--- The Heathkit came today and IT WORKS!!! There is some very light hum but I don't see any reason to recap it. Besides, it is very hard to get to the electrolytic caps. The kit builder's work was not great but acceptable.
I'm listing the Tenma today at a buy it now price of $85.
I don't know if it was worth $167. But at least I have one and I don't have to worry about it any more.
BTW- If you factor in the money I spent on amp kits it is over $200
terrydec
terrydec
Post by John Bartley on Wed Feb 01, 2017 4:44 pm
It's good to hear that you are back in business. I think that the fun factor outweighs the dollar factor where hobbies are concerned .... so enjoy!
John Bartley
Post by terrydec on Wed Feb 01, 2017 5:09 pm
John Bartley wrote:It's good to hear that you are back in business. I think that the fun factor outweighs the dollar factor where hobbies are concerned .... so enjoy!
I agree. Obviously
terrydec
terrydec
Post by willy3486 on Thu Feb 02, 2017 11:14 am
On radios when someone asks if it is worth it I say this unless the radio is just a huge ripoff and I tell them that. I tell them radios are not an investment unless you get cheap and flip it. I tell them if the radio is 50 bucks for it and if you will get 50 bucks or more enjoyment from it buy it. If you get less than 50 bucks of enjoyment then pass. This is a hobby , not a profession so look at the enjoyment factor.
Post by terrydec on Thu Feb 02, 2017 12:37 pm
Yep!
I just sold the Tenma for $100, (twice what I paid), so that takes away some of the bite
terrydec
terrydec
Post by John Bartley on Thu Feb 02, 2017 1:25 pm
terrydec wrote:Yep!
Good for you! It's always nice when things go our way ... for a change! Smile
John Bartley
