Solid core wire replaced with stranded wire?
Post by Sccy9er on Wed Jan 04, 2017 7:29 pm
About to start on a GE A-52 , I noticed much of the rubber coated solid core wire on the underside of chassis has lots of cracks and exposed wire, my question is if its ok to replace it with stranded wire ,I'm guessing it may work since stranded has more surface area but would like to get advice from more experienced folks.
Sccy9er
Number of posts : 8
Registration date : 2016-12-20
Re: Solid core wire replaced with stranded wire?
Post by Bill Cahill on Wed Jan 04, 2017 9:36 pm
Electrically, there is no difference. However, for neatness, and, in some circuits, it's critical to put the wire exactly where the original wire was. For those, I prefer to use non stranded wire.
Number of posts : 4548
Post by Sccy9er on Thu Jan 05, 2017 3:28 pm
Thanks for the info
Sccy9er
Number of posts : 8
Post by terrydec on Sat Jan 07, 2017 12:26 pm
I can see some possible problems. Stray strands could cause shorts and some pieces might not go through terminals. Also, like Bill said, some wires depend on strength to maintain position.
terrydec
Number of posts : 1058
Post by Spivey on Sat Jan 07, 2017 5:40 pm
Solid core for me is just easier to work with.
Spivey
Number of posts : 24
Post by jukeboxman on Sat Jan 07, 2017 8:29 pm
Hi as bill and the others said --solid would be best -a lot of circuits
depend on the wire being close to the original location -being off can cause tuned circuits to pick up stray hum or other odd signals like motor boating or squeals- and change only one wire at a time keeping the length as close as you can to original
GARY
(Jukebox Man)
jukeboxman
Number of posts : 130
Post by Sccy9er on Mon Jan 09, 2017 2:00 pm
Awesome thanks for the help
Sccy9er
Number of posts : 8
