Edison Amberola X Part
Post by Andy K on Sat Dec 10, 2016 3:39 pm
Hello , I'm looking for the screw that secures the reproducer weight to the reproducer main housing. The reproducer is a Diamond "B" type off a an Edison Amberola X. If anyone has one they would like to sell, or knows where I can get one I would appreciate the info.
Thanks Andy K
Andy K
Number of posts : 1
Registration date : 2015-04-10
Re: Edison Amberola X Part
Post by Bill Cahill on Sun Dec 11, 2016 9:07 am
First off, welcome to TRF, Andy. That is a hard one. It's a large screw with a long shoulder, it screws into a bottom piece at the bottom of the stack. Shoulder screw, weight spring, ten bottom. I'm missing something, somewhere. The weight should float, and, move easily from side to side. The limit pin should be inside the limit loop mounted on underside of the main body.
There are two tiny pins that fit into the tiny holes on the reproducer spring.
Hope this helps.
Number of posts : 4583
Post by Bill Cahill on Sat Jan 21, 2017 2:29 pm
Andy, are you having any luck?
Post by Bill Cahill on Tue Jan 24, 2017 10:57 pm
http://www.ebay.com/itm/EDISON-PHONOGRAPH-DIAMOND-C-REPRODUCER-TAIL-WEIGHT-/192086074357?hash=item2cb938e3f5:g:y2cAAOSw-0xYhobc
Here is thee link to a dealer I deal with a lot. He might be able to help you.
