Morris Coil Winder info
Post by John Bartley on Wed Dec 07, 2016 11:40 am
This is the scans I made of the owners manual for a Morris Coil Winder and a scan of the dial disc. Someone may be able to use the info.
John Bartley
Number of posts : 144
Re: Morris Coil Winder info
Post by Bill Cahill on Wed Dec 07, 2016 4:09 pm
At one time, John Folsom could have used one of those winders.
Number of posts : 4583
Post by CrystalRadioMan on Wed Feb 08, 2017 6:51 pm
I would love to have one of those today. Are they still available?
CrystalRadioMan
Number of posts : 8
Registration date : 2017-02-08
Post by John Bartley on Wed Feb 08, 2017 8:24 pm
You can find them used. They used to run about $100 used.
John Bartley
Post by John Bartley on Wed Feb 08, 2017 8:27 pm
http://www.ebay.ca/itm/VINTAGE-MORRIS-COIL-WINDER-/142262044161?hash=item211f7a8601:g:KRkAAOSw241Yjqc1
It appears I wasn't too far off.
John Bartley
Its not all there...
Post by Chas on Sun Apr 30, 2017 10:35 am
That ebay winder has some missing bits. A shaft the supports the wire guide and serves as a cam follower. A return spring and clip the allows the cam to follow.
Although Morris never made any model distinction there is a model with a cast iron frame. Parts that clamp 11 pins t to make spider web coils, two versions, one with a split cast hub and another with a pair of embossed flat washers.
There were some changes to various clamps, gears and collars, to make them less costly.
I bought one of these new as a boy, from Allied, even then the frame was cast aluminum... FWIR I wrote to them (Morris, MoReCo) and got additional gears of different tooth counts and additional cams. I made a cam to swing 1" to make lumped inductances... I may have the letter around, seems there was some association with a clothing manufacturer. Then they went out of the winder biz.
Chas
Chas
Number of posts : 89
Post by John Bartley on Sun Apr 30, 2017 12:06 pm
A couple of those winder photos from the auction before they are gone from view :
John Bartley
