Sylvania SY-247
Sylvania SY-247
Post by shunkpenn on Mon Oct 31, 2016 10:58 pm
Hello all.....why is it I can't find anything on this tube. I guess it's just a regular type 47. It's a beautiful big old globe tube...just found it in one of my boxes.
shunkpenn
Number of posts : 21
Registration date : 2016-10-18
Re: Sylvania SY-247
Post by 75X11 on Tue Nov 01, 2016 3:01 pm
Those old getters sure blew a lot of metal around in there, didn't they? Nice tube and box. At least it gives a clue as to it's function.
Re: Sylvania SY-247
Post by shunkpenn on Tue Nov 01, 2016 5:31 pm
This is a interesting little bugger as well....don't think there are too many of these around.  It was made specifically for this radio....almost looks like it could have been made by GE.
shunkpenn
Re: Sylvania SY-247
Post by John Bartley on Tue Nov 01, 2016 5:39 pm
Re : the tube in the post directly above this one (not the 247)
That's an interesting tube. I did a bit of Googling for "Freshman Master B Eliminator" and came up with this :
https://books.google.ca/books?id=2CgDAAAAMBAJ&pg=PA117&lpg=PA117&dq=%22freshman+master+b+eliminator%22&source=bl&ots=83bu4EYe6x&sig=SBsygRmqt6BDP8Xi--Yo_l1llRo&hl=en&sa=X&ved=0ahUKEwiAt92YtIjQAhUX0IMKHSPwD_UQ6AEIITAB#v=onepage&q=%22freshman%20master%20b%20eliminator%22&f=false
And this, which appears to be your tube but from another builder :
http://www.radiomuseum.org/tubes/tube_ux216b.html
John Bartley
Number of posts : 147
Re: Sylvania SY-247
Post by shunkpenn on Tue Nov 01, 2016 6:19 pm
John....very interesting. Thanks.
shunkpenn
Re: Sylvania SY-247
Post by John Bartley on Tue Nov 01, 2016 7:39 pm
shunkpenn wrote:John....very interesting.  Thanks.
You are welcome, but I would encourage you to keep an open mind that the tube may be something else completely different than what I have suggested. That is just what my first googling turned up.
cheers
John
John Bartley
Re: Sylvania SY-247
Post by shunkpenn on Tue Nov 01, 2016 8:27 pm
John...I took a look at both links and I may not be convinced that this is exactly the same tube. The interesting thing is I can't find one pic online that looks like this tube. The RCA UX216B is not of the same construction....however I think this tube served the saved principle of the UX216B. Maybe this tube came out in the first year of production with the radios?
shunkpenn
Re: Sylvania SY-247
Post by Bill Cahill on Tue Nov 01, 2016 10:28 pm
How many pins does your tube have???
Number of posts : 4590
Re: Sylvania SY-247
Post by shunkpenn on Tue Nov 01, 2016 11:23 pm
Bill...it's a 4 pin
shunkpenn
Re: Sylvania SY-247
Post by Bill Cahill on Wed Nov 02, 2016 5:11 pm
That brass based one looks like a gas filled rectifier used in early power supplies to eliminate having to use batteries. Majestic, and, some others made these power supplies. They made thee B voltage for the tubes on battery powered sets.
The one with the 247 on the base is actually the tube number. But, I thought it was a five pin tube. I could be wrong. But, a four pin tube would normally be two filament pins, a grid pin, and, a plate pin. No cathode.
It's fairly early. Possibly about 1924.
Re: Sylvania SY-247
