Rocket Escape System Test
Post by 75X11 on Wed Oct 05, 2016 2:48 pm
The rocket launches, deploys the escape stage, then lands in proper sci-fi style!
https://www.washingtonpost.com/news/the-switch/wp/2016/10/05/why-jeff-bezos-may-crash-his-historic-rocket/
Re: Rocket Escape System Test
Post by jerryhawthorne on Wed Oct 05, 2016 6:49 pm
Now that is impressive! Both retrieved. Not that I'm ready to go for a flight but private systems are doing very well. Where is NASA?
Number of posts : 731
Post by 75X11 on Wed Oct 05, 2016 7:06 pm
Haven't you heard? They have a new version of the Apollo capsule atop one of those fun shuttle solid rocket boosters.
Post by jerryhawthorne on Wed Oct 05, 2016 7:38 pm
I worked for Beckman back when solid rockets were made by Thikol in the Salt lake area. I will say they were strong. They also periodicaly blew up the bunker they were tested in. I sold a lot of IR spectros to them that they used to monitor fuel. I would really feel more comfortable if they solved the O-ring problem they had earlier. Not certain their problem but probably NASA. Solid fuel is just not controllable but gives great force and lighter. Once lighted well your off!
Post by Guest on Wed Oct 05, 2016 7:41 pm
Proper sci-fi style for sure! Very Happy
Post by 75X11 on Wed Oct 05, 2016 8:02 pm
jerryhawthorne wrote:I worked for Beckman back when solid rockets were made by Thikol in the Salt lake area.  I will say they were strong.  They also periodicaly blew up the bunker they were tested in.  I sold a lot of IR spectros to them that they used to monitor fuel.  I would really feel more comfortable if they solved the O-ring problem they had earlier.  Not certain their problem but probably NASA.  Solid fuel is just not controllable but gives great force and lighter.  Once lighted well your off!
I used to work not way too far from where they did some of their testing out on the test and training range. Sometimes you could see the sky flicker a bit when they did evening tests.
Post by jerryhawthorne on Thu Oct 06, 2016 2:21 am
75, my dad worked at rocketdyne in So. CA and took me up one night to watch a test firing of one of their large engines on a test stand up in the mountains. Talk about lighting up the sky!
Post by 75X11 on Thu Oct 06, 2016 9:14 am
Those were the days!
