Kinda quiet around here...
Post by Dr. Radio on Sun Oct 02, 2016 11:02 am
Just sayin' Smile
Don't have much exciting to share, but will when the time comes.
You guys doing ok?
Re: Kinda quiet around here...
Post by Wildcat445 on Sun Oct 02, 2016 11:44 am
I'm getting ready to go someplace warm for the winter. I scored a pile of records at an auction the other day. I posted a blurb about that, on the Phongraph and Records board. Other than that, quiet as a church house around my place.
Oh yeah, and I can't get my little Heathkit scope to work.
Post by Tony V on Sun Oct 02, 2016 3:47 pm
WC...anymore work on your Magnavox?
Number of posts : 633
Post by Guest on Sun Oct 02, 2016 6:27 pm
I think many members are getting ready for winter and closing up all their outside concerns, I know I am! Very Happy
Post by Wildcat445 on Sun Oct 02, 2016 6:30 pm
Tony, since I finished the restore on my little Concerto, there are no more left to do. I am going to overhaul the MPX adapters in the Symphony and Imperial in AZ this winter. If you'd like, I could post those projects on here. And, if I find a Stereo Theater, that might make a project of some type.
Post by Guest on Sun Oct 02, 2016 6:55 pm
Please do WC! Very Happy
Post by Wildcat445 on Sun Oct 02, 2016 7:07 pm
I could also make a project out of my busted scope.
I bought a Heathkit IO-12 scope at an auction for $3. I don't have probes for it, so I used the probes for my VTVM with it. I used the scope that way to do the alignment on the tuner and MPX adapter on my Concerto stereo. Now I can't get my scope to show a trace. It comes on, I can adjust it, but I can't get it to show a trace. The scope is all original, caps, tubes, the whole thing. Either a component has failed, or I got lucky using it with VTVM probes the last time, or I'm not holding my mouth right. I need that scope to go thru an MPX adapter correctly. There is not much to one, but it needs set up properly to work.
Post by 75X11 on Sun Oct 02, 2016 7:41 pm
You might get an inexpensive contemporary x10 probe for it , check a few signal sources and see what you get.
Post by 75X11 on Sun Oct 02, 2016 7:45 pm
I've been working on the Mustang.  The rear oil drain plug  wore out and boogered up the threads, so I had to tap in an oversize plug to cease it's leaking.  The radiator overflow reservoir  opened a leak, too so I had to replace it.  I had to clean up those things before sending it out to have the heater core replaced.  Now I am going to try some DX'ing on my Magnavox.
Post by Wildcat445 on Sun Oct 02, 2016 8:06 pm
Is your Mustang one of those with a drain plug on the front of the pan and one on the rear, with a little hump over the steering rack? And an aluminum oil pan? With a rear sump?
Post by Dr. Radio on Mon Oct 03, 2016 9:04 pm
Speaking of cars. I got to get going again before it gets too cold to work in the garage. More interior to reinstall in the '70 Chevelle. (Yes, I do all my own work. I had a professional shop install the new headliner, but that was it). Smile
Post by Wildcat445 on Mon Oct 03, 2016 9:10 pm
Nice work, Doc. Very Happy
Post by Guest on Mon Oct 03, 2016 9:42 pm
very nice! Is that a clock radio I see on the shelf while looking through the drivers side window?
Post by Wildcat445 on Mon Oct 03, 2016 9:53 pm
Doc, do you do your own stitching work, or do you install kits? Either way, I'm impressed. How's about coming to sunny Arizona this winter and doing a little black leather work on an old Buick?
Post by Wildcat445 on Fri Oct 07, 2016 12:14 am
I fixed my scope. Embarassed
Post by 75X11 on Fri Oct 07, 2016 1:27 am
Well?  What was it? Very Happy
Post by Conelrad on Fri Oct 07, 2016 1:45 am
I have an original vintage Tek: http://w140.com/tekwiki/wiki/310
Does everything needed in the retro Radio Ranch.
Dennis
Conelrad
Number of posts : 94
Post by Wildcat445 on Fri Oct 07, 2016 10:46 am
I also have an old Tek 532. The thing is massive and dims the lights in the community when I fire it up. With the plug-in it has 77 tubes. It has a 6AL5 that hangs upside down that suffers from a wonky tube socket. I frequently need to remove the side panel and wiggle that tube to get a trace on it. It has its own roll around cart and is just cute as it can be, although I don't use it much. I like the little Heathkit scope since it is miniscule in size in comparison and it is not so finicky about working. Usually.
What did I find the matter with my scope, you ask? Did you notice the emoticon after my post? I got a probe off ebay and thought all was well. This time I could not even get a trace at all. Somehow the horizontal positioning control got turned all the way one way and that moved the trace enough I could not see it. My ORIGINAL problem was that I did not have the time base set properly. I've gotta quit tinkering with my test equipment. I will eventually tinker myself out of business. Embarassed
Post by Guest on Fri Oct 07, 2016 11:30 am
I think we could start a thread on embarrassing moments in electronics.
I've had quite a few myself! Embarassed Embarassed Embarassed
Post by Wildcat445 on Fri Oct 07, 2016 11:55 am
If I revealed every embarrassing moment I've had lately........ Embarassed
Post by Dr. Radio on Sat Oct 08, 2016 8:07 pm
MEZLAW wrote:very nice!   Is that a clock radio I see on the shelf while looking through the drivers side window?
Yup Mr. Mez. Smile My garage is an "overflow catch-all" for my many clock radios.
Circa 1965 General Electric all transistor clock radio with simulated wood grain finish.
Circa 1976 Zenith "Circle of Sound" Digital Clock AM/FM radio.
Post by Dr. Radio on Sat Oct 08, 2016 8:11 pm
Wildcat445 wrote:Doc, do you do your own stitching work, or do you install kits?  Either way, I'm impressed.  How's about coming to sunny Arizona this winter and doing a little black leather work on an old Buick?
I don't know if I could do the Buick justice. I work with "Poor Man's Leather" (vinyl), never real leather. Smile These are reproduction pieces pre-assembled. Despite the fact they were made in the U.S.A. and $$, I still had to do a LOT of "fitting" to get things right. Seat covers require finesse , heat, muscle, planning and hog rings Smile
Door panels require, fitting, refitting, more refitting and finishing with modifying and refitting Sad   Smile
I go to great lengths to make things fit and LOOK right. I once told someone, even if a person knows nothing about old cars, they can certainly spot a wrinkle, non-symmetry etc.
I also pretend to know what I'm doing under the hood. Smile
Post by Bill Cahill on Mon Oct 10, 2016 10:45 am
I think it's a good idea to start a new thread, and, I think it should go in the club house.
I have many very embarrassing moments to ell about.....
Number of posts : 4561
Post by 75X11 on Mon Oct 10, 2016 2:28 pm
Bill, If you feel like starting one, Please do it! We will post in it. You are just as good at it as any of us.
Post by Wildcat445 on Mon Oct 10, 2016 5:24 pm
Nice work, Doc.
