IF coils needed
IF coils needed
Post by Switcher on Sun Mar 01, 2009 10:12 pm
Rogers Majestic Model M-15 Which I believe to a Majestc radio
I've removed the can and also the top adjustment pad.
The coil has two forms one, inside the other.
The inner form has one winding. It's open
The outer form has two windings on it. One is open
Yes, if I can not find the coil I need I will try to disassemble and rewind.
Here is a look at the rest of the mess that I have to clean up from the previous (restorer's) good quality work Rolling Eyes
This one may take some time.
Switcher
Number of posts: 29
Registration date: 2008-03-13
http://www.radiopreservationguy.com
Re: IF coils needed
Post by DA on Mon Mar 02, 2009 11:51 am
You might be able to repair it using the method described in note 7 at the bottom of this web page:
http://www.qsl.net/k5bcq/102/102.html
DA
Number of posts: 13
Registration date: 2009-02-10
http://www.99main.com/~allens/
Re: IF coils needed
Post by Switcher on Mon Mar 02, 2009 7:59 pm
Thanks DA. I've used that method before, but I thought I would troll for a replacement first and if not then on to the surgery department. Thanks.
Switcher
Number of posts: 29
