New toyz............ Photos on the way.............
Page 3 of 3 Previous  1, 2, 3
Re: New toyz............ Photos on the way.............
Post by jukeboxman on Sun Jun 19, 2016 10:35 am
Very nice --enjoy
GARY
(Jukebox Man)
jukeboxman
Number of posts : 145
Post by Bill Cahill on Thu Jun 23, 2016 9:18 am
Well, bad luck happened. At ten am mandrel was nearly straight. At five o'clock, it was wobbling wildly. Not good. Talked to our friend Tony, and, he says it sounds like metal fatigue. No guarantees, but, it looks like it to me, also. I'll have to look for another mandrel.
Phooey!
Number of posts : 4583
Post by Bill Cahill on Thu Jun 23, 2016 4:48 pm
Hmmm.. Now, I'm not so sure. It is now straighter. I might not have been bending the shaft as well as I had thought.
Post by Bill Cahill on Thu Jun 30, 2016 10:55 am
Mandrel is still bouncing, and, motor got louder.I put machine back together, and, for the first time, ever, I put the blue horn on. Yesterday, volume was low. Today, it's louder.
Still some bounce, though....
Post by Wildcat445 on Thu Jun 30, 2016 11:15 am
Bill, I admire your tenacity. I would have given up long ago. Good luck! Very Happy
Post by Bill Cahill on Thu Jun 30, 2016 11:43 am
Thank you. I don't know why you would have. It physically is in beautiful condition. It now plays, though still needing further work....
Post by Bill Cahill on Sat Jul 02, 2016 4:24 pm
I think I finally have mandrel shaft nearly straight. Machine plays well, though still not loud enough.
Motor can barely heard.
Not bad for a 100 year old machine.
It plays three blue amberols on a winding.....
Post by Bill Cahill on Mon Jul 04, 2016 5:10 pm
Mechanical problem solved!!!!!!!!!
I worked on bent mandrel shaft more today. Used the eyes from a friend to check it out.
It has got just one tiny bounce left, and, I'm leaving it alone. Records play nicely with good sound.
Next step is to finish the cabinet work. Then, completed machine will go to another room to enjoy it.
Post by Bill Cahill on Tue Jul 12, 2016 12:30 pm
I'm going to try to insert pictures. My Avast was blocking the forum.Been having a lot of trouble with it.
Nope. Still doesn't work. I also have lost my automatic cursor movement now.
Post by Bill Cahill on Wed Sep 14, 2016 9:00 pm
Still no luck. Mandrel is still slightly bent, and, belt is slipping. Need to shorten it. Reproducer is much l0uder. I replaced original horn bracket because it was highly rusted....
Been busy. Hope to work on belt tomorrow morning.
Post by Bill Cahill on Thu Oct 06, 2016 11:28 am
I worked on the belt, which is now doing well. I kept working on bent shaft, and, the bounce is nearly gone. However, Now, when you pick carriage up, and, put it in the non playing position, without half nut touching the feed screw, it is much worse about needle playing the record because something just isn't right.
Post by 75X11 on Thu Oct 06, 2016 11:36 am
You'll get it set straight.
Post by Bill Cahill on Thu Oct 06, 2016 12:14 pm
http://www.ebay.com/itm/EDISON-STANDARD-MODEL-E-PHONOGRAPH-WITH-HIGH-SERIAL-NUMBER-800566-PROJECT-/201468436938?_trksid=p2047675.l2557&ssPageName=STRK%3AMESINDXX%3AIT&nma=true&si=nf41P99IOd6tTQa01tHWt9tjy5A%253D&orig_cvip=true&rt=nc
Those are pictures of it while it was on ebay. I'm having trouble not being able to put computer pictures in posts.
Post by Bill Cahill on Tue Oct 25, 2016 12:14 pm
Still am working on the Edison Standard. Mandrel shaft was badly bent. I had been going through the mandrel to find bends, and, wonderiwng why my adjustments were making it worse. This morning I discovered the reason. Somebody had tried to break it loose by banging he mandrel with his tool. It got bent. Now, I'm watching the bend closely on the center shaft. Finally, it's improving.....
If I get time this week, I'll take pictures of it here, and, ask someone to post them for me....
Post by Bill Cahill on Mon Nov 14, 2016 10:04 am
Well, I've finally done about all the work on the mechanical aspects of the standard. The mandrel shaft was extremely bent.The mandrel itself also has some dents in it, which don't help a lot. This machine was battered.
I have got very little gear noise, and, you can hear some gear noise out of the governor. I still have to work on the rest of the machine. All, in all, it's playing better. It still doesn't like to start on it's own. I suspect the main spring was wound up tight for many years, ad, got somewhat weak. Still a slight bounce, also. The reproducer has it's issues, also. Machine is getting louder out of the horn every day. Reproducer needs rebuilding, though. Needle is good. The reproducer is a rare model N.
Post by Bill Cahill on Tue Nov 22, 2016 9:58 am
I now have the standard on proud display in my music room.
Looks nice, and plays beautifully. I've got the Gem back on the bench to replace the broken main spring.
Post by Bill Cahill on Fri Nov 25, 2016 12:22 am
Found the problem that caused spring to break.
First gear off bull gear is no longer holding to whaft. It allowed motor to go on free spin, and, spring broke. Also, some damage was done to winding check gear. a few of the gear for spring back wareds not to happen also has some damage.
I'll have to find parts for this Gem machine.........
Post by Bill Cahill on Mon Dec 05, 2016 8:13 pm
I'm trying to insert a picture from my computer. So far, no luck.
Post by Bill Cahill on Mon Dec 05, 2016 8:30 pm
Some of my things are showing up, again. But, I still can't show photos.
Post by John Bartley on Tue Dec 06, 2016 12:36 pm
Bill, I thought that attachments were disabled on this board? You might have to upload your pic's to a photo hosting site and then link to them there instead of trying to upload them as attachments from your computer?
John Bartley
Number of posts : 144
Post by Bill Cahill on Mon Dec 26, 2016 10:03 am
Yes, use it, but, try to not to overwind it......
Post by Bill Cahill on Tue Dec 27, 2016 10:15 pm
I lucked out on ebay. Lost the chance to win the rare rproducer for my Edison Diamond Disc A 150 machine.
But, I bought the bedplate, and, horn for same. The paint on both is very good, and, it seems to have a quiet motor. It has 98 percent perfect paint, pin striping, and, horn. Main spring is good. I can hardly wait to switch parts. My motor on the Bailey Teeters Machine is badly worn.
The mechanism on this one is complete original.
I'm glad I've got it.
Post by Bill Cahill on Sat Jan 07, 2017 11:07 pm
More good news... I just purchased a basket case rare Model c Edison standard. They onl sold in NY state due to patents that Columbia held on the open ended mandrel. When Columbia let go of the patents for that, Edison came up with his own version of the the open ended mamdrel.
The model C was the first machine that had it, and, the last machine with only a two minuite settin.
It arrived this afternoon... Ah......A new project. I'll have 11 cylinder phonographs......
