New toyz............ Photos on the way.............
Re: New toyz............ Photos on the way.............
Post by Bill Cahill on Mon May 23, 2016 10:26 am
Sort of. Not all springs fail. My model B Standard is running on it's original spring along with most others. This one just had a weak spot. My guess is right at winding shaft. I got cheated on spring barrel on my B Home. He advertised it as having a new main spring. When it broke two years ago, my frind that installed a new spring for me said the old one was original, and,broken in six places.
Number of posts : 4590
Post by Bill Cahill on Mon May 23, 2016 9:42 pm
Gear train arrived. However, it's making a loud noise. Hope it's just dirty.
Post by Bill Cahill on Tue May 31, 2016 7:40 am
I got the good gear cover last Saturday. It's beautiful. Makes the machine look almost new. Cleaned main spring, and, greased it.
Found part of the problem with lack of power. Dammage on mandrel shaft. I'm working on that, and, re doing belt.
I also found top gearing is causing part of the problem.
The machine looks almost brand new.
Post by 75X11 on Tue May 31, 2016 9:21 am
Looks like it's coming along.
Post by Bill Cahill on Thu Jun 02, 2016 5:53 pm
I've started taking pictures of Gem, Standard horn, and, Standard, Plus, a standard I bought back from John Folsom after I got home from nursing home, and, a model D Home I bought last year.
Haven't installed them in computer, yet, But, hope to tomorrow. Can someone volunteer to let me e mail them, and, they install them In this thread??? Much thanks for your patience. Batteries in camera were dead.
Post by Bill Cahill on Sat Jun 04, 2016 3:20 pm
Last night, I discovered that shaft was also bent behind the pulley.. I did some straightening on that part. It now plays twoand, a half four minuite records on a winding...
That's an improvement.....
Post by Bill Cahill on Fri Jun 10, 2016 11:22 am
I tried uploading pictures, and, it said I have no room to upload the file. Can somebody help me?? Give me your email address, and, I'll email them to you. Thanks.
Post by Bill Cahill on Fri Jun 10, 2016 11:24 am
Other than that, I'm still trying to straighten mandrel shaft. It's doing better, but, I have some ways to go....
Post by Bill Cahill on Tue Jun 14, 2016 9:23 am
I need help. I have 13 pictures I want to install, and, none of the things Tony told me about are showing up on my computer. Yes, I'm logged in. Would somebody be willing to send me an e mail, and, I'lll forward the photos to you so you can install them?? Thanks.
Post by Tony V on Tue Jun 14, 2016 7:37 pm
I offered to do them for you....
Number of posts : 663
Post by 75X11 on Tue Jun 14, 2016 8:30 pm
Bill, do you see this icon I have circled? that is the one we are talking about to host a picture.
Post by 75X11 on Tue Jun 14, 2016 8:32 pm
After you press the icon you will get this window.
You first press select files to locate your picture files on your computer then open your picture, then press select all.
Post by Bill Cahill on Wed Jun 15, 2016 10:10 am
I'm sorry, but, those icons are not shoing up for me.
Post by 75X11 on Wed Jun 15, 2016 10:32 am
Okay, I just wanted to make certain. It looks like your webpage doesn't show up like ours. Tony has said he will post them for you.
Post by Bill Cahill on Wed Jun 15, 2016 12:05 pm
I forwarded my pictures to Tony. He should get them in his email today.
I tried turning off my Avast, but, it made no fifference.
I've been different problems with my web server. I wonder if IE could be blocking me from doing it.
Post by 75X11 on Wed Jun 15, 2016 2:30 pm
I use firefox with IE and it doesn't block it. Have you tried the proprietors of this domain? maybe it is held from administrators, or needs to be accessed in a special way.
Post by Tony V on Wed Jun 15, 2016 10:03 pm
These are the photo's Bill emailed me to post of his phonographs and horn. There were a couple of duplicates so i omitted those. Bill can come back and fill in descriptions of each photo later. Enjoy!
This is the model E Standard as it is on the bench right now.
Still doing repairs..
This is a closer front view of my model E standard.
The next two pictures are of my Model A standard I bought back from John Folsom.
Post by Tony V on Wed Jun 15, 2016 10:10 pm
These are two pictures of the horn that will be on the standard model E.
These two pictures show two slightly different views of top of Standard model E.
Post by Tony V on Wed Jun 15, 2016 10:13 pm
This is the two min. Edison Gem model B after it broke the main spring.
Post by Bill Cahill on Thu Jun 16, 2016 12:27 pm
Been working dillgently on mandrel shaft on model E standard. It's real close. Much less bounce, and, runs stronger. Main spring appears to be good.
Post by 75X11 on Thu Jun 16, 2016 1:52 pm
Hope you get them all running as good as they are looking!
Post by Bill Cahill on Thu Jun 16, 2016 7:07 pm
Thank You very much. Most of my machines play beautifully.
Little by little, things are improving. The fun part is getting them working, and, looking as much as possible to what they were like new......
Somehow, I'll get my Edison Gem playing again.....
I enjoy this very much....
Post by 75X11 on Thu Jun 16, 2016 7:20 pm
It's great you are back to doing it. Your threads are what drew me to this site in the first place.
Post by Wildcat445 on Thu Jun 16, 2016 9:35 pm
Looking good there, Bill. Very Happy
Post by Bill Cahill on Fri Jun 17, 2016 9:17 am
Thanks, guys.. Been busy, so, couldn't work on it yesterday. The mandrel shaft on the standard is still slightly bent, but, improving.. Spring appears good. I noticed one thing. On machines that were used a lot, the plating on mandrel, and, brake lever is thin. On the ones not having as much use, you can tell from both the looks, and, feel of the parts that the plating is thicker...
Funny.. Croaking Frog, my dealer in NY, sold me a ratty gear cover, which I didn't like. A week after, he had the cover I have with it now for sale. Condition is the same as machine. Excellent paint with mint pin striping.
This machine will be almost like new.
Even the motor has very little gear noise....
